For Roundcube, no managed interface in Nethgui and Cockpit, no settings and no possibility to enable or disable…
Moved your request from #bug to #feature.
What Rouncube settings do you find we could benefit from having them on the server-manager?
In first, enable or disable the module.
In nethgui, it is done already done for:
- ejabberd
- Fail2ban
- Mattermost
- SOGo
In Cockpit, it is done already done for:
- ejabberd
- Fail2ban
- Mattermost
SOGo is missing in Cockpit -> Applications:
it is about 13 thousand lines of code needed, only to enable or disable roundcube, does it sounds really essential
The developer team is good, with a huge willingness but his time is limited
For admins/users of a nice server, yes
Then the work could start by a PR on
the status prop is not implemented, this is an example how it can be implemented
the default status prop must be created also in
after that the roundcubemail could be set to disabled.
…and of these, only Mattermost is a web application (and IMO, the enable/disable setting is redundant). Once again: what benefit is there to disabling an installed web application?
Example, disable for:
- Some tests by the administator
- Security problem
- A temporary request from the CTO, CIO, …
…and how does simply uninstalling the application not accomplish the desired result?
Why we need to uninstall some applications if we must to install it again?
In that specific case a status prop is welcome to disable roundcubemail in the apache configuration
Yes for this specific PHP app, it can be a desactivation in the webserver.
I have seen that there are 2 possibilities of links, by defaut it must be only one “webmail” not “webmail” + “roundcubemail”.
Maybe we can have user possibility to choice manual link (https://domain.tld/XXXX and https://XXX.domain.tld/ in the configuration page (nethgui + cockpit).
It can be possible to have with this same base for phpMyAdmin…
talk is cheap, I am waiting PR now
please detail what you are willing to do, we could valid what and not what to do and the best approach
1/ Minimum default settings page in Nethgui and Cockpit:
- Enable/Disable the app
- Choice the link: https://domain.tld/XXXX and have the possibility to have https://xxx.domain.tld/XXXX (domain.tld can be the main domain or other domain).
This is not only for Roundcube, phpMyAdmin, all other PHP apps…
Do not forget that if the app has a link, this link must be in Applications part of Netgui and Cockpit.
In Cockpit, for Nextcloud: there is a link to the software and “Settings” page
You can change in the same time:
- Webmail | Provides Webmail with RoundcubeMail for NethServer
-> - Roundcube | Provides Webmail
or - Roundcube | Provides Roundcube Webmail
agreed, first this should be done manually by a prop, not sure the panel is needed now
this could lead to issue with fail2ban, not sure it is good, the path is watched by fail2ban
How it is done currently with?
- Mattermost
- Nextcloud
mattermost there is no jail IIRC
for nextcloud you can check https://github.com/NethServer/nethserver-fail2ban/blob/master/root/etc/fail2ban/filter.d/nextcloud-auth.conf
but this is my example, check the jail of phpmyadmin, we look after the path https://github.com/NethServer/nethserver-fail2ban/blob/master/root/etc/fail2ban/filter.d/phpmyadmin.conf
Obviously maybe we could adapt it of course, but it is time, tests and so long
My message was about it works with Mattermost and Nextcloud, so it is possible for other apps too
