ok i’have restore the snap and the error is present . I’have modifying only ip connection to database 192.168.3.76 to > 10.5.4.1 vpn ip .
The piwigo is ready to connection !
Thank you as always for helping me and the community.
I’have resolved in GLPI with same parameter for smtp send email .
Hello @france
could you do something for me, I have webserver to test and I am loooking for someone to test it
Basically it is upgrade of nginx and php version, minor version so not much big bang expected
see Upgrade webserver components (Nginx, SFTPGo, PHP-FPM) · Issue #7083 · NethServer/dev · GitHub
take a snapshot before but I hope no breaking changes
at the end php version is up and upgraded, nginx also
to test, drop a phpinfo in you vhost to see the php version, do a 404 (wrong url) you should see the nginx version
Hi Sthepane , gladly if I can help you of course . Maybe if I can in the late afternoon towards evening, I’ll try to take a snapshot, and run what you put in the link.
cooooooooooooooooooooooooooool
in another french word
topissime
I added a new test case, we have upgraded the version of sftpgo, better UI, no 30 files limitation … nice to have
Excellent sthepane, I can’t wait to try it. But I’ll be able to do it in the late afternoon.
See you later and thank you for making me participate in your work.
@davidep brings me a clue
[root@R1 ~]# podman --version
podman version 5.2.2
it seems we have a breaking changes and we cannot retrieve the internal LAN IP like we did before
[root@ns8 ~]# podman --version
[root@ns8 ~]# api-cli run update-module --data '{"module_url":"ghcr.io/nethserver/webserver:1.0.20-dev.1","instances":["webserver1"],"force":true}'
Warning: using user "cluster" credentials from the environment
<7>podman pull ghcr.io/nethserver/webserver:1.0.20-dev.1
Trying to pull ghcr.io/nethserver/webserver:1.0.20-dev.1...
Copying blob sha256:b91b73bdb9a4780357c4ac8c8ce1f2b3665aa6d8b9414b4013d5fe01c5fec6e6
Copying config sha256:a98a110d06a59ffa4e79672099f7fde04a4232501a088c0f8bf51726c7ab2f10
<7>extract-ui ghcr.io/nethserver/webserver:1.0.20-dev.1
Extracting container filesystem ui to /var/lib/nethserver/cluster/ui/apps/webserver1.abe8da76
ui/css/
ui/css/about~31ecd969.aaeac019.css
ui/css/app~748942c6.93585bfa.css
ui/i18n/
ui/i18n/de/
ui/i18n/de/translation.json
ui/i18n/en/
ui/i18n/en/translation.json
ui/i18n/es/
ui/i18n/es/translation.json
ui/i18n/eu/
ui/i18n/eu/translation.json
ui/i18n/it/
ui/i18n/it/translation.json
ui/i18n/pt/
ui/i18n/pt/translation.json
ui/i18n/pt_BR/
ui/i18n/pt_BR/translation.json
ui/img/
ui/img/module_default_logo.63283db0.png
ui/index.html
ui/js/
ui/js/about~31ecd969.c0a0434f.js
ui/js/about~31ecd969.c0a0434f.js.map
ui/js/app~748942c6.fbf60a04.js
ui/js/app~748942c6.fbf60a04.js.map
ui/js/chunk-vendors~02576867.44c88c8d.js
ui/js/chunk-vendors~02576867.44c88c8d.js.map
ui/js/chunk-vendors~0605657e.7f254d6a.js
ui/js/chunk-vendors~0605657e.7f254d6a.js.map
ui/js/chunk-vendors~0f485567.5bca6cdf.js
ui/js/chunk-vendors~0f485567.5bca6cdf.js.map
ui/js/chunk-vendors~17faf02d.7f68aab6.js
ui/js/chunk-vendors~17faf02d.7f68aab6.js.map
ui/js/chunk-vendors~1d97ff09.290bda9d.js
ui/js/chunk-vendors~1d97ff09.290bda9d.js.map
ui/js/chunk-vendors~2a42e354.0df57e14.js
ui/js/chunk-vendors~2a42e354.0df57e14.js.map
ui/js/chunk-vendors~2aa62147.38204dba.js
ui/js/chunk-vendors~2aa62147.38204dba.js.map
ui/js/chunk-vendors~41d44f25.e7779fa1.js
ui/js/chunk-vendors~41d44f25.e7779fa1.js.map
ui/js/chunk-vendors~46852254.0b6d19c2.js
ui/js/chunk-vendors~46852254.0b6d19c2.js.map
ui/js/chunk-vendors~57473a66.f586d2ed.js
ui/js/chunk-vendors~57473a66.f586d2ed.js.map
ui/js/chunk-vendors~5bb1f863.3efba861.js
ui/js/chunk-vendors~5bb1f863.3efba861.js.map
ui/js/chunk-vendors~5eba3806.b8428291.js
ui/js/chunk-vendors~5eba3806.b8428291.js.map
ui/js/chunk-vendors~690b702c.fd888ae3.js
ui/js/chunk-vendors~690b702c.fd888ae3.js.map
ui/js/chunk-vendors~7274e1de.abde9fa5.js
ui/js/chunk-vendors~7274e1de.abde9fa5.js.map
ui/js/chunk-vendors~86f6b1bc.cd957566.js
ui/js/chunk-vendors~86f6b1bc.cd957566.js.map
ui/js/chunk-vendors~b5906859.deff14e4.js
ui/js/chunk-vendors~b5906859.deff14e4.js.map
ui/js/chunk-vendors~bc21d4b3.68b10b46.js
ui/js/chunk-vendors~bc21d4b3.68b10b46.js.map
ui/js/chunk-vendors~c8728516.dd1ccc58.js
ui/js/chunk-vendors~c8728516.dd1ccc58.js.map
ui/js/chunk-vendors~d2305125.6a99a4ff.js
ui/js/chunk-vendors~d2305125.6a99a4ff.js.map
ui/js/chunk-vendors~d9886323.1a1a66f6.js
ui/js/chunk-vendors~d9886323.1a1a66f6.js.map
ui/js/chunk-vendors~db300d2f.ddb8641c.js
ui/js/chunk-vendors~db300d2f.ddb8641c.js.map
ui/js/chunk-vendors~ec8c427e.5c1734c3.js
ui/js/chunk-vendors~ec8c427e.5c1734c3.js.map
ui/js/chunk-vendors~fdc6512a.81c5c86c.js
ui/js/chunk-vendors~fdc6512a.81c5c86c.js.map
ui/js/lang-de-translation-json~3c620948.5c2de49c.js
ui/js/lang-de-translation-json~3c620948.5c2de49c.js.map
ui/js/lang-en-translation-json~9b60384d.1f5f30fb.js
ui/js/lang-en-translation-json~9b60384d.1f5f30fb.js.map
ui/js/lang-es-translation-json~f7c30340.9e619109.js
ui/js/lang-es-translation-json~f7c30340.9e619109.js.map
ui/js/lang-eu-translation-json~8ed4c5c2.3d61a174.js
ui/js/lang-eu-translation-json~8ed4c5c2.3d61a174.js.map
ui/js/lang-it-translation-json~e043826f.b6cdc13d.js
ui/js/lang-it-translation-json~e043826f.b6cdc13d.js.map
ui/js/lang-pt-translation-json~45d767f3.5dd0b7a0.js
ui/js/lang-pt-translation-json~45d767f3.5dd0b7a0.js.map
ui/js/lang-pt_BR-translation-json~eef7148a.b6f91606.js
ui/js/lang-pt_BR-translation-json~eef7148a.b6f91606.js.map
ui/metadata.json
ui/shortcuts.json
165c4512df8443d1c18d065146e614e493b56fed1c5f5cd075bfe36632bbc4d3
<7>rm -rf '/var/lib/nethserver/cluster/ui/apps/webserver1.abe8da76~'
<7>podman rmi --ignore ghcr.io/nethserver/webserver:1.0.19
Untagged: ghcr.io/nethserver/webserver:1.0.19
Deleted: bb2b34c336b53e96ac5287a50dbd8d44919763076e4810e5f67649486455bfcd
[root@ns8 ~]#
I’m executing command for upgrade module , and 'have reboot server . At moment all app is running .
Because we are human, not robot, nore AI, because we are not enough, because people are asking what NethServer can do for them and not what they can do for NethServer
I can continue a long time like that Laylow, please we try to do our best but sometime it is not enough.
You always have to appreciate what you do and what others do for everyone. I believe that when you try to understand how to solve a problem and face it according to your knowledge and skills, it is the basis to always reach the goal. Personally, I have never solved problems that I am not able to solve, but the facts show that having discovered and raised doubts and problems has allowed other more experienced users to arrive at the solution, a solution for the common good
@stephdl exactly what you show and are. Nethesis cntrol is a different thing. You know you are very much appreciated!
hello France
new version
Could you check
and check also
