NethServer Version: 7.5.1804 Module: Web Content Filter
Is there any place into nethgui for review and edit the global whitelist?
As far as i can see i can only add domains or URLS… but i am not able to view the whitelist and edit removing no more allowed domains/URLS.
Or maybe my way to manage “always allow that sites” seems… wrong?
Even in your screenshot the save button (at the right of the page) is not visible…
Anyway, a little… Feature improve or workaround:
starting from a carriage-returned list, add massively domains and URL.
Maybe a textbox or a multi-line list.
Seems not working…
I added via nethguy some domains. Therefore i used your notation for add some other domain: no error received from shell, but no more DomainWhitelist added on list.
Anyway, instruction for batch add domains and URLs could be added to documentation.
@mrmarkuz the file /var/squidguard/blacklist/custom/whitelist/domains is generated by a template in /etc/e-smith/templates/var/squidguard/blacklist/custom/whitelist/ if I understood correctly.
With a template custom a simple file could be use to add a bulk of domains to this file, only not to be maintainable by GUI. What do you think?
You can edit the file with a editor like notepad++ save it and do the signal-event. Not that elegant as by GUI, but workable and not to complicated IMO.
But you can also make a feature request to @dev_team.
Ok, “thanks but no thanks”… I suggest to add this feature (batch add whitelisted domains) but it’s not “critical”.
Unless it goes throught over 80 domains par batch…
