yes I did the restart of the test, I even did a server reboot. But the result hasn’t changed.
you could try renaming the dump.rdb. it’s re-created by itself or should I create one myself?
The db should be recreated at the service restart, you could remove/move it
IIRC you have some log relative to redis under /var/log
the file (dump.rdb) is not recreated.
I also restarted the server.
because the service doesn’t start I bet
In fact, that’s my problem
