NS7 - fully updated
I need to use:
- python-csv
- python-os
- python-urllib
Are these present by default on NS7, and if not, how/where can I get them pls?
TIA
NS7 - fully updated
I need to use:
TIA
Consider that basically Nethserver is… CentOS. You can install your modules “as usual” if you are using CentOS7.
Thanks, but what exactly is ‘as usual’ pls? yum can’t find them in the default repo’s and I believe Python also works with PIP, but I rather not do that. Obviously, I never use Python, just an application wan’t those modules.
Thanks.
Edit: I found that all modules are installed by default. Thanks!
