Problems withe Only Office Documentserver, cant create Documents in Nextcloud
To analyze:
Is documentserver running?
Check https://yourNethServer:8082.
systemctl status nginx -l
supervisord restart all
Is the Nextcloud onlyoffice app installed and enabled and setup correctly?
Check Nextcloud admin settings for correct IP/FQDN. If you used the package get the instructions in the wiki else in the howto.
Yes, there is a downgrade workaround to try…
I tried it and the workaround works with the module, I don’t know the exact steps for the ones who installed via howto by now…
VPN yes, but no access via SSH or Web UI. The server is dead.
Thanks for clarifying…
I updated the wiki entry for a fresh installation. I put yum install https://github.com/ONLYOFFICE/DocumentServer/releases/download/ONLYOFFICE-DocumentServer-5.0.7/onlyoffice-documentserver.x86_64.rpm instead of using the repo. I tested it on a VM and it worked.
For an already updated broken installation when using the nethserver-onlyoffice package I recommend the downgrade:
yum downgrade https://github.com/ONLYOFFICE/DocumentServer/releases/download/ONLYOFFICE-DocumentServer-5.0.7/onlyoffice-documentserver.x86_64.rpm
signal-event nethserver-onlyoffice-update
yum remove onlyoffice-repo
For those who used the howto I recommend to downgrade and install the package as it corrects wrong configuration files:
yum -y install https://smart-ict.services/mirror/mrmarkuz/7/noarch/nethserver-mrmarkuz-0.0.1-1.ns7.noarch.rpm
yum -y install nethserver-onlyoffice
Check the wiki entry for instructions when using self-signed cert and how to set correct hostname…
Fully agree. With the downgrade/direct install way we keep the working version and may care about the update without pressure.
Can you make onlyoffice work again with the provided solution? @fausp Thanks in advance!
Yes, it worked.
Edit:
If onlyoffice-documentserver was installed from their repo, until further notice it’s better to disable or remove the repo as it will be triggered by updates and bork it again:
Sorry, the downgrade did not work for me… I restored the NS7-vm and installed it new, thanks to you Markus :clap:
grafik
Thanks, I added it to the solution post and changed the workaround link in the wiki.
