seem to be facing a challenge installing Nethserver
Error: Package: netdata-1.32.1-1.el7.x86_64 (epel)
Requires: nodejs
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
Configuring system, please wait…
Failed to execute operation: No such file or directory
/usr/sbin/nethserver-install: line 45: /sbin/e-smith/signal-event: No such file or directory
You can access the Web interface at:
/usr/sbin/nethserver-install: line 51: /sbin/e-smith/db: No such file or directory
/usr/sbin/nethserver-install: line 52: /sbin/e-smith/db: No such file or directory
https://.:9090/usr/sbin/nethserver-install: line 48: /sbin/e-smith/db: No such file or directory
Login: root
Password: <your_root_password>
