NethServer Version: 7.9.2009
Module: email
I have a new nethserver with 4 domains say d1 to d4
I need separate info@ accounts for each domain so I have users info1, info2, info3 and info4
I can add those addresses and all is fine.
If I try to add john@d1 to john1 user it works but the other domains to john2, john3 and john4 fail.
When I click on create after a few seconds it just stops and does not close the popup box.
I suspect I may have created an address pointing at more than one domain before this happened, but I have deleted all john addresses and started again.
If I create a user test I cannot use that as a destination for john@d3 or d4
I can complete the above for jon@ but the guy’s name is John.
It feels like there is something lingering in a file or database that says the address is already being used, even though I have deleted it (on the server web interface)
I have spent a whole day searching but have failed to find any help, so apologies if the answer is somewhere “obvious”, I have struggled to find terms to search on.
The only applications I have installed are email, webmail, crontab manager, web server and anti virus.
Thanks
