[SOLVED] PPPoE and Web proxy issues
Hi everybody,
I encountered the following situation:
I have a PPPoE Internet connection.
When I try to use Web proxy in “Transparent mode” or “Transparent with SSL” in conjunction with “Block HTTP and HTTPS ports”, after I press “SUBMIT” button I receive an error message at the end of the task (please see the “Task error” attached picture).
After many tries, I observed that the error appear only if I have PPPoE connection (please see attached picture). If I configure NIC with fixed IP, I have no errors.
Thank you in advance for help!
Kind regards,
Gabriel
Hi, show pls :
cat /etc/shorewall/zones
Hi Nas,
This is now.
I will reproduce the task and I will show you the file just after the error.
Thank you!
cat /etc/shorewall/hosts
cat /etc/shorewall/interfaces
Just after errors?
Pictures for zones and rules just after errors:
so where is PPPOE zone ) find it :slight_smile:
have you update your instalation ?
so no pppoe zone , that is why errors persist.
have you update your system ?
If there is no pppoe zone, how the NS works?
The system is up-to-date.
I made all the updates just after first login. After that, I began the configuration of the NS.
show:
db networks show
and show /etc/shorewall/policy
so there is a bug in
/etc/e-smith/templates/etc/shorewall/rules/90squid
edit line 31
next if ($role eq ‘’ || $role eq ‘red’ || $role eq ‘slave’ || $role eq ‘bridged’ || $role eq ‘alias’ || $role eq ‘pppoe’);
and try to recreate.
It works!
Thank you!
i should make fork on GIT :slight_smile: thanks for testing
You should!
Thank you for help! :beers:
already forked. You should make custom template for this file , coz while dev team add it to distro may pass some time.
mkdir -p /etc/e-smith/templates-custom/etc/shorewall/rules
cp /etc/e-smith/templates/etc/shorewall/rules/90squid /etc/e-smith/templates-custom/etc/shorewall/rules/90squid
