Our SIP provider request us to do the following in order to allow SIP traffic between us and them :
Ask the person who manages your router/firewall to allow outgoing traffic to the IP range: 37.59.194.64/27 (/27 means that the subnet mask is 255.255.255.224)
If the router/firewall supports QoS (Quality of Service), assign a higher priority to the trafic exchanged with our IP range
Some routers also include a feature called SIP ALG (Application-level gateway - Wikipedia). Our experience shows that SIP ALG is often poorly implemented on low-cost routers and that it is better to disable SIP ALG
Make sure that the default NAT session timeout is > 30 seconds
I think you’re talking about nf_conntrack_sip kernel module which should be already loaded.
We didn’t experienced any problem so far on our installations (@Stll0 can correct me if I’m wrong).
SIP packets already have the correct TOS which is honored.
I suspect the server is configured incorrectly in networking, there is no way a 192.168.x.x address should be on the RED port. What IP address does the green port have?
Actually not. Because I wasn’t able to create a pppoe connection directly from NS to my provider, I had to use the one embedded in the DSL modem. I configured it widely open (DMZ mode).
There is certainly a double NAT issue, but until now no real world problem asfaik. Still investigating why I can’t connect directly though pppoe.
That appears to be an attempt to connect to port 11780 on the firewall itself. Is the application listening for the SIP traffic running on the NS server, or behind it. If behind, then you need a port forward rule for 11780.
Indeed, the port 11780 is the one where the VOIP phone is listening.
However, it is impossible to know which phone will listen to what port beforehand : the assignation is dynamic and part of the SIP protocol when establishing the call.
That said, everything is working correctly; that’s for the sake of learning something
Do you have Double NAT on your network? Then you have 2 firewalls/gateways to configure.
Internet - ISP router - NethServer - Local Lan
External IP addres on RED interface of ISP router
internal IP address on Green interface of ISP router 192.168.178.0/24 subnet
External IP address on RED interface of NS 192.168.178.23
internal IP address on GREEN interface NethServer (subnet for local LAN)
If possible you could ask your ISP to put the router in bridge mode so your NS gets an external IP address
otherwise you have to do the correct portforwarding on your ISP router and also open the ports on the ISP router to make the connection. Theoreticly double NAT shouldn’t be a showstopper.
/edit: I should read the whole thread before posting… lol
