Piler failed after Installtion on NS8
Module: Piler
after installing Piler on the NS8 it finalizing with an error. Get configuration Operation not authorized
Cannot retrieve configuration Operation not authorized
any Ideas?
After a few time completely nuts, have installed the ns8 system around 10 times i got again the error after installing the Piler Sytem. It finished the Installation with an error, something is going wrong, but the installation of the app finished, if i try to configure the Piler i got again an error
Get status Operation not authorized
I recently did the same without issues. Can you provide any Log excerpt?
sure, here wo go:
2025-02-03T11:01:01+01:00 [1:piler1:systemd] Queued start job for default target Main User Target.
2025-02-03T11:01:01+01:00 [1:piler1:systemd] Created slice User Application Slice.
2025-02-03T11:01:01+01:00 [1:piler1:systemd] Started Mark boot as successful after the user session has run 2 minutes.
2025-02-03T11:01:01+01:00 [1:piler1:systemd] Started Daily Cleanup of User’s Temporary Directories.
2025-02-03T11:01:01+01:00 [1:piler1:systemd] Reached target Paths.
2025-02-03T11:01:01+01:00 [1:piler1:systemd] Reached target Timers.
2025-02-03T11:01:01+01:00 [1:piler1:systemd] Starting D-Bus User Message Bus Socket…
2025-02-03T11:01:01+01:00 [1:piler1:systemd] Starting Create User’s Volatile Files and Directories…
2025-02-03T11:01:01+01:00 [1:piler1:systemd] Listening on D-Bus User Message Bus Socket.
2025-02-03T11:01:01+01:00 [1:piler1:systemd] Reached target Sockets.
2025-02-03T11:01:01+01:00 [1:piler1:systemd] Finished Create User’s Volatile Files and Directories.
2025-02-03T11:01:01+01:00 [1:piler1:systemd] Reached target Basic System.
2025-02-03T11:01:01+01:00 [1:piler1:systemd] Started Rootless module/piler1 agent.
2025-02-03T11:01:01+01:00 [1:piler1:systemd] Reached target Main User Target.
2025-02-03T11:01:01+01:00 [1:piler1:systemd] Startup finished in 547ms.
2025-02-03T11:01:01+01:00 [1:piler1:agent@piler1] task/module/piler1/d19d0819-c8df-4ffa-a7a4-fd52f27d38a9: create-module/05pullimages is starting
2025-02-03T11:01:01+01:00 [1:piler1:agent@piler1] Add to module/piler1 environment PILER_IMAGE=docker.io/sutoj/piler:1.4.4
2025-02-03T11:01:01+01:00 [1:piler1:agent@piler1] Add to module/piler1 environment MARIADB_IMAGE=docker.io/mariadb:10.11.7
2025-02-03T11:01:01+01:00 [1:piler1:agent@piler1] Add to module/piler1 environment MEMCACHED_IMAGE=docker.io/memcached:1.6.26-alpine
2025-02-03T11:01:01+01:00 [1:piler1:agent@piler1] podman-pull-missing docker.io/sutoj/piler:1.4.4 docker.io/mariadb:10.11.7 docker.io/memcached:1.6.26-alpine
2025-02-03T11:01:01+01:00 [1:piler1:systemd] Starting D-Bus User Message Bus…
2025-02-03T11:01:01+01:00 [1:piler1:systemd] Started D-Bus User Message Bus.
2025-02-03T11:01:01+01:00 [1:piler1:dbus-broker-launch] Policy to allow eavesdropping in /usr/share/dbus-1/session.conf +31: Eavesdropping is deprecated and ignored
2025-02-03T11:01:01+01:00 [1:piler1:dbus-broker-launch] Policy to allow eavesdropping in /usr/share/dbus-1/session.conf +33: Eavesdropping is deprecated and ignored
2025-02-03T11:01:01+01:00 [1:piler1:] Ready
2025-02-03T11:01:01+01:00 [1:piler1:systemd] Created slice Slice /user.
2025-02-03T11:01:01+01:00 [1:piler1:systemd] podman-pause-4a9e700d.scope: unit configures an IP firewall, but not running as root.
2025-02-03T11:01:01+01:00 [1:piler1:systemd] (This warning is only shown for the first unit using IP firewalling.)
2025-02-03T11:01:01+01:00 [1:piler1:systemd] Started podman-pause-4a9e700d.scope.
2025-02-03T11:01:01+01:00 [1:piler1:agent@piler1] Trying to pull docker.io/sutoj/piler:1.4.4
2025-02-03T11:01:18+01:00 [1:piler1:agent@piler1] Error: parsing image configuration: Get “https://pkg-containers.githubusercontent.com/ghcr1/blobs/sha256:627775a81726132f04cea1503d0aafb36effc7d3dadd52a0bf3427f0b9a9d60d?se=2025-02-03T10%3A10%3A00Z&sig=nRPczxk9RXtKEmAFDXmpXxrr6%2Fm9x5C140UTs07RgzQ%3D&sp=r&spr=https&sr=b&sv=2019-12-12”: dial tcp: lookup pkg-containers.githubusercontent.com on 192.168.100.206:53: no such host
2025-02-03T11:01:18+01:00 [1:piler1:agent@piler1] Traceback (most recent call last):
2025-02-03T11:01:18+01:00 [1:piler1:agent@piler1] File “/usr/local/agent/bin/podman-pull-missing”, line 35, in
2025-02-03T11:01:18+01:00 [1:piler1:agent@piler1] subprocess.run([‘podman’, ‘pull’, image_url]).check_returncode()
2025-02-03T11:01:18+01:00 [1:piler1:agent@piler1] File “/usr/lib64/python3.11/subprocess.py”, line 502, in check_returncode
2025-02-03T11:01:18+01:00 [1:piler1:agent@piler1] subprocess.CalledProcessError: Command '[‘podman’, ‘pull’, 'docker.io/sutoj/piler:1.4.4’]’ returned non-zero exit status 125.
2025-02-03T11:01:18+01:00 [1:piler1:agent@piler1] raise CalledProcessError(self.returncode, self.args, self.stdout,
2025-02-03T11:01:18+01:00 [1:piler1:agent@piler1] File “/usr/local/agent/actions/create-module/05pullimages”, line 48, in
2025-02-03T11:01:18+01:00 [1:piler1:agent@piler1] agent.run_helper(‘podman-pull-missing’, *images).check_returncode()
2025-02-03T11:01:18+01:00 [1:piler1:agent@piler1] subprocess.CalledProcessError: Command '(‘podman-pull-missing’, ‘docker.io/sutoj/piler:1.4.4’, ‘docker.io/mariadb:10.11.7’, 'docker.io/memcached:1.6.26-alpine’)’ returned non-zero exit status 1.
2025-02-03T11:01:18+01:00 [1:piler1:agent@piler1] task/module/piler1/d19d0819-c8df-4ffa-a7a4-fd52f27d38a9: action “create-module” status is “aborted” (1) at step 05pullimages
2025-02-03T11:03:55+01:00 [1:piler1:systemd] Starting Mark boot as successful…
2025-02-03T11:03:55+01:00 [1:piler1:systemd] Finished Mark boot as successful.
2025-02-03T11:06:55+01:00 [1:piler1:systemd] Created slice User Background Tasks Slice.
2025-02-03T11:06:55+01:00 [1:piler1:systemd] Starting Cleanup of User’s Temporary Files and Directories…
2025-02-03T11:06:55+01:00 [1:piler1:systemd] Finished Cleanup of User’s Temporary Files and Directories.
2025-02-03T11:11:23+01:00 [1:piler1:agent@piler1] task/module/piler1/9ef359aa-3a97-45ed-83a9-72d54b63ae17: configure-backup/50write_systemd_units is starting
2025-02-03T11:11:25+01:00 [1:piler1:agent@piler1] Created symlink /home/piler1/.config/systemd/user/timers.target.wants/backup1.timer → /home/piler1/.config/systemd/user/backup1.timer.
2025-02-03T11:11:25+01:00 [1:piler1:systemd] Reloading.
2025-02-03T11:11:25+01:00 [1:piler1:systemd] Started Sicherung nach NAS.
2025-02-03T11:11:26+01:00 [1:piler1:agent@piler1] task/module/piler1/9ef359aa-3a97-45ed-83a9-72d54b63ae17: action “configure-backup” status is “completed” (0) at step 50write_systemd_units
The error message indicates a simple DNS error…
lookup [pkg-containers.githubusercontent.com](http://pkg-containers.githubusercontent.com) on 192.168.100.206:53: no such host
i have no idea what happened. i am able to ping the ns8 server from the network also directly on the machine etc. etc. but i am not longer able to install one App, tried it with piler dnsmasq or at least with fetchmail… i have no idea where to search
