Hi guys,
I was looking at the phone home map on http://www.nethserver.org/phone-home/widget_map.html and noticed that there are no installations, no data. Maybe it is a kind of maintenance?
Hi guys,
Try using https
on the link https://www.nethserver.org/phone-home/widget_map.html.
Anyway the new url is: https://www.nethserver.org/phone-home/
HTTPS works. Thank you, I found the link pointing me to http here:
https://www.nethserver.org/learn-more/
<a href="http://www.nethserver.org/phone-home/widget_map.html" target="_blank"><img src="https://www.nethserver.org/wp-content/uploads/2014/04/here.png" width="1832" height="821" alt="here" /></a>
Fixed, thanks for the heads-up
