Hi again.
How can I change the Owncloud language?
Best regards
Hi again.
Best regards
I changed the users configuration in the owncloud user settings but I want to change the login screen also.
I found this in the owncloud site but I don’t know where to put the default_language parameter in the file.
I tried but didn’t work
Solved.
Trying to change the wrong file
The Owncloud guide ir correct.
You need to set the default_language parameter.
1 - Check the list of supported language codes at /var/www/html/owncloud/settings/languageCodes.php
2 - Add or change the default language at /var/www/html/owncloud/config/config.php
Best Regards
In normal cases ownCloud will automatically detect the language of the Web-GUI, doesn’t happen in your case?
Was detected and insraled in Portuguese
1 or 2 days after changed to english and I don’t know why. (did’t do anything.
Changed the language at the config files and everything is good until today
