NethServer Version: 7.5.1804 (final) Module: email
Hello,
am I right in my understanding of the “dovecot DeletedToTrash” function/setting?
It does not move the “deleted” marked email to trash but copy?
It does not create the “Trash” folder, Trash has to be created on another way, ex. by deleting a message in roundcube. The Docs say: You should also change Outlook configuration to hide deleted messages from inbox folder. This configuration is available in the options menu.
My tests with Outlook 2007 show that the deleted message still resides in the INBOX after deleting, but it’s in Trash too.
To get rid of the marked messages in INBOX, one may set "Account=>General=>“delete elements online when changing folders” (badly translated from german)
It does move it but Outlook still shows it in the inbox when the options are not set. In newer versions “delete elements online when changing folders” seems to be default.
As Markus said, it’s an Outlook behaviour. But in Outlook is also an option to move them to the trash or leave them in INBOX.
Have a look at the photo:
The setting says:
Mark elements to delete, but don’t move them automatically.
If you don’t mark this checkbox the mails are moved to trash.
Please have a look at Folder (Ordner) Tab, I think it’s there.
Edit!!! OK, at Outlook 2007 there’s no option to do it.
Only options are upgrading to Outlook 2010 or newer, or to take a client which could better work with IMAP as Outlook (in every version) can. Thunderbird could be an option here.
That way you just hide the messages, but they keep using space. I see them in roundcube too, it’s not just an outlook view problem.
I can live with this behaviour, just wanted to make sure I don’t miss something.
