As it stands right now the Advanced Fieldset with the Options “Route all client traffic through VPN” and
"Allow client-to-client network traffic" is only Available for Routed mode, and I’m curious as to why it’s just limited to the one. I can edit the config manually no problem, except if I change an option via the UI I’ll need to make sure push “redirect-gateway def1” is put back into the config.
Usage scenario nethserver 7:
I have nethserver sitting out there on a box with one NIC so in order to utilize openVPN I need to create a bridge on a vlan and use that vlan with OpenVPN. As part of this scenario I would like to force all traffic through the VPN.
Just curious why its limited; Thoughts, Comments, or am I just not utilizing this correctly ?
Thanks!
