Hi everyone
I need to use in OpenVPN a port diferent than 1194.
Where can I change that?
Hi everyone
Can you help?
db vpn setprop YourNameVpn RemotePort 5555
signal-event nethserver-vpn-save
Does someone can confirm it ?
In fact you can, have a look yourself (of course if you know it)
[root@nethserver-dev ~] # config show openvpn
BridgeEndIP=
BridgeName=br0
BridgeStartIP=
ClientToClient=disabled
Compression=enabled
Mode=routed
Netmask=
Network=
RouteToVPN=disabled
ServerStatus=disabled
TapInterface=tap0
UDPPort=1194
access=public
status=enabled
and since there are no values saved ( UDPPort=1194 is needed for the firewall) then you have to search by another way
[root@nethserver-dev ~]# grep -srni '1194' /etc/e-smith/
/etc/e-smith/db/configuration/defaults/openvpn/UDPPort:1:1194
/etc/e-smith/events/nethserver-vpn-create/S30nethserver-openvpn-genclient:32:my $RemotePort = $openvpn->prop('RemotePort') || '1194';
/etc/e-smith/events/actions/nethserver-openvpn-genclient:32:my $RemotePort = $openvpn->prop('RemotePort') || '1194';
/etc/e-smith/events/nethserver-vpn-modify/S30nethserver-openvpn-genclient:32:my $RemotePort = $openvpn->prop('RemotePort') || '1194';
Here you have to understood and read some code inside template…but fortunately perl is easy to read
Right commands are:
config setprop openvpn UDPPort 5555
signal-event nethserver-openvpn-save
signal-event firewall-adjust
thanks giacomo
it should be written here http://docs.nethserver.org/en/latest/vpn.html
Thanks for your confirmation! Let’s ask a pull request for the documentation as requested by @stephdl
@giacomo
Does the IPSEC port can be changed…I looked after the UDPPort with grep but I didn’t find something interesting.
After that I looked and forked the documentation GitHub repository but how trade with foreign Languages, I can see Spanish and Italian. My wife is Spanish, therefore I could write in Spanish, but for Italian, do I need to change my Wife ?
Ahahaha nope, take a look at this:
You can calm your wife down
Therefore, official changes are made in English
Hi @giacomo I’m not trying to demonstrate my knowledge but I’m looking about services that need a nethgui entry to change port directly inside it.
So I’m searching to understand what you did for other services .
When I look about openvpn
[root@nethserver-dev ~]# ls -R /etc/e-smith/events/nethserver-openvpn-save/
/etc/e-smith/events/nethserver-openvpn-save/:
S30nethserver-openvpn-delserver S80firewall-adjust services2adjust templates2expand
/etc/e-smith/events/nethserver-openvpn-save/services2adjust:
openvpn
/etc/e-smith/events/nethserver-openvpn-save/templates2expand:
etc
/etc/e-smith/events/nethserver-openvpn-save/templates2expand/etc:
openvpn
/etc/e-smith/events/nethserver-openvpn-save/templates2expand/etc/openvpn:
host-to-net.conf host-to-net.pool
Thus I can see that the action firewall-adjust is already called, do we need to launch it again twice ?
No, we don’t Sorry but I didn’t check the code at time of answer…and to be sure, I just suggested to fire the firewall event.
Thank you for the clarification!
