If you have 2 NICs (Network Interface Cards) in your NethServer, and one is connected to the Internet (Provider Box) and the other connects to your LAN, then you have a NethServer as your Gateway…
that’s correct i’m in this current test setup.
next step is the insertion of the wifi on the appropriate card
here I am,
then i succeeded with this rule, source green destination red service dns action drop and it crashes everything. thank you. for the possible blocking of p2p protocols for example under which service are they inserted? I can not find them
you must know the range of ports you want to block. Otherwise you have another way, block everything but allow only some ports, generally speaking it is often harder to make than to say
ok thanks.
I have to do some insights because I realized that with this rule, unfortunately you no longer navigate in any way. I have to try to block only the udp protocol of port 53
Is it possible to signal the developers to make this change?
maybe you should debug on the client which dns it uses
