NS8 Webserver questions
hello, new version GitHub · Where software is built
app update worked (fopen working , and no further replacing existing virtual host). sftpgo version updated correctly as on the former dev version.
Grande dnutan
@france could you confirm ?
Before saying yes I have to try again with a snapshot, I assumed that once you solved it there was no need to do another test. But I remind you that Murphy’s law is universal, so I’ll try again and let you know.
I’m retrying upgrade a fix , but in my case the old virtual host is missing BUT the old app is running
The old virtual host hostname is webapp.internal.lan
What is the content of the file
/home/webserver1/.config/state/databases/NextFpmPort
I cant now verify now . Tomorrow i retrying , i creating a snap and reporting for you
the port of database before upgrade is 9000
thank, ok it is a new bug, either you can restore to the previous version, thank, I know what to do
To explain, the file was static, and it overwrites each time the values to 9000. this file is incremented each time you create a vhost, it is the ID of the next vhost you will create
once you have restored the version with your snapshot, check the value, if you have one vhost, it must be set to 9002, can you please verify it
If not you can set it manually
ok , I’m wait you with resolve this bug and 'I’m later retrying to test .
hello
if you can valid it or not, the issue with NextFpmPort should be solved, plese ask for any question
not recommended but if you want to try it directly on a real webserver, just update to 1.0.20-dev.4, but be sure to get a snapshot to going back
Hi Stephane , in your version dev4 of web server , the bug is resolved . i’have execute a snap of server and upgrading the version. I’have create a new virtual host . The old virtual host after the creation is present and the number of databases was increase to 9002 . i’have connect to interface for manage the virtual host and the new structure is empty , so this is correctly .
[root@ns8 state]# ls
CACHEDIR.TAG  agent.env  apitoken.cache  conf.d  databases  environment  php8.2-fpm-custom.d  php8.3-fpm-custom.d  sftpgo.conf.d
[root@ns8 state]# cd databases/
[root@ns8 databases]# ls
NextFpmPort  vhosts
[root@ns8 databases]# less NextFpmPort
[root@ns8 databases]# cd vhosts/
[root@ns8 vhosts]# ls
9001.ini  9002.ini
[root@ns8 vhosts]#
after I’m reboot the server and retry to connect I web server for validate the upgrade . Is ok .
Thank you very very much . “Stefano” …
Grazie a tutti per il supporto
released as Release 1.0.20 · NethServer/ns8-webserver · GitHub
