[NS8] Safe upgrade path for Paperless-ngx module (v1.3.1 / core v2.11.4)
Hi everyone,
I am running the Paperless-ngx module maintained by @oneitonitram ( Package paperlessngx · GitHub ) on a production NethServer 8 instance. Everything works great, but I would like to update Paperless-ngx to a more recent version (the instance is currently running core app version 2.11.4).
Currently, Software Center shows no available updates for this module.
Here is my current environment setup:
  • NS8 Module: ghcr.io/compgeniuses/paperlessngx:1.3.1
  • Paperless-ngx: docker.io/paperlessngx/paperless-ngx:2.11.4
  • PostgreSQL: postgres:15.5-bookworm
  • Redis: redis:7.2.3-bookworm
  • Gotenberg: gotenberg:8.9.1
  • Apache Tika: tika:3.0.0.0-BETA2-full
Before manually tweaking the PAPERLESS_NGX_IMAGE variable in environment (which I know carries risks regarding database migrations, Traefik proxy configuration, or breaking webserver changes introduced in Paperless 2.15+), I would like to ask:
  1. Is there an update planned for the official compgeniuses/paperlessngx module package?
  2. What is the recommended/supported procedure for upgrading the underlying core Paperless-ngx image manually on NS8 without breaking system integration?
Thanks in advance for any insights and guidance!
Hello Szymon,
this comply with the latest release that @oneitonitram delivered on his github account
The module allows the container platform of NS8 to have a working instance Paperless-NGX.
Which is… two steps ahead: currently latest version was published yesterday, 3.3.1
which means, two major version upgrade are needed.
IDK which is the status of @oneitonitram about this specific module, maybe you can help developing an upgrade path or being available to test updates on a spare/reserve installation.
Community modules rely only on contributors (as people willing to help) and community to keep the pace.
It is possible to work on an Upgrade, and a working upgrade path to the latest version.
We have an internal tracker, hopefully, we can open it up, for all the apps we build, their releases, breaking changes etc.
the first works on the upgrades, we had attempted to implement SSO into the APp, which broke our tests, and thats when we stopped.
I would be happy if i could get someone to Help in actively testing the Builds we make and we can Begin working on an Upgrade path, with tagged, blockers for upgrades paths to prevent breaking peoples running instances.
How does this weekend Sound Like for testing, I can work a few Upgrades before Friday, to the most recent non breaking version…
@kemboielvis22 had also began some preliminary updates
Hi @oneitonitram and everyone,
Thank you so much for the quick response and for all the hard work you put into maintaining this module! It’s awesome to hear that work on the upgrade path is moving forward.
Regarding SSO: Interestingly, I have actually been using SSO (logging in with Active Directory accounts) in my Paperless-ngx setup for a long time now. I set it up using the Authentik module on NethServer 8 (in a similar way to how Nextcloud integrates with it), and it has been working very smoothly in my environment.
As for testing: This weekend sounds great! I am more than happy to help test the new builds and provide feedback on a spare test installation. Just let me know where to pull the test builds from or what instructions to follow when you are ready.
Thanks again for driving this forward!
I also found the dependence on developers for updates increasingly cumbersome. An extreme example is HermesAgent, which has several hundred changes every day. No module developer can keep up with that.
I also found it unpleasant for everyone involved to have to keep begging for updates.
That’s why I switched to installing LXC on Proxmox to remain independent.
I now only install NS8 apps that are also integrated with AD/Samba. Otherwise, the drawbacks outweigh the benefits.
It’s part of the tradeoff of “community” modules. On one hand the NS8 adopters can access a bigger pool of experiencese. On the other hand, it’s the developer of the module that is in charge of that.
I can see why: non-podman-based recipes for containers are far more available, and NS8 recipes are a small subset of the podman-ones.
PVE is a far superior product than NS8 currently. The second one sometimes is easier to maintain if you keep the official module-recipes only.
its far much easier to maintain products deployed with coolify, than one with PXE, especially LXC containers…
