Hi Davide,
I had a failure on my usb local backup a week ago and thought I’d debug why it kept failing. I’m running a single-node NS8, Core 3.x, local USB backup via rclone-gateway WebDAV.
Symptom: Scheduled backup marks samba1 failed; ~300 GB restic backup succeeds; retention (forget --prune) fails with exit 11. Redis shows errors: 1 but data is restorable. UI History shows no error detail.
Stale lock: repository is already locked by PID 1 on motueka — lock from an interrupted run (~Aug 4). Plain restic unlock does not remove it (host PID 1 = systemd still alive). unlock --remove-all clears it.
Repro: agent.run_restic → forget --prune after successful module-backup fails until --remove-all. Manual restic-wrapper forget sometimes appeared OK; run-backup path uses agent.run_restic with 0s lock wait.
Local workaround: Retry retention after unlock --remove-all in run_retention() (or always before prune).
Happy to open a GitHub issue on ns8-core if useful — not urgent on our side after workaround. My patch as below:
def run_retention(rdb, repository, repopath, retention):
"""Apply retention policy after a successful backup. Returns True on success, False on failure."""
forget_args = ["forget", "--prune", f"--keep-last={retention}"]
try:
agent.run_restic(rdb, repository, repopath, [], forget_args, check=True)
return True
except Exception as ex:
print(f"[ERROR] retention policy failed for {repository}/{repopath}: {ex}", file=sys.stderr)
print("Retrying after stale lock cleanup...", file=sys.stderr)
try:
agent.run_restic(rdb, repository, repopath, [], ["unlock", "--remove-all"], check=False)
return True
except Exception as ex2:
print(f"[ERROR] retention policy failed after unlock retry for {repository}/{repopath}: {ex2}", file=sys.stderr)
return False
It may need a bit of improvement as done rather quickly.. and only a couple of test runs, thanks for you time,
Turbond
(aka Mad Matt)
