Ns8 Nextcloud and ElasticSearch
Hi there,
Longtime ago…just a compliment to ns8!
Now i handle with a Nextcloud problem. I do not get connection with elasticsearch. “No Alive nodes”
I used the address http:\\localhost:9200
Perhaps anyone had a similar problem, fixed it and has a good advise for me?
Thx
maddin
A lot more info is needed like versions installed, base platform versions, did it work before, what has changed, what modules have you installed in Nextcloud, did you search for ‘no alive nodes found) on the Nextcloud forums, do you believe this is a specific Nethserver issue?.
AI suggests:
The error "No alive nodes. All the 1 nodes seem to be down" in Nextcloud with Elasticsearch typically indicates that **Elasticsearch is not running or is unreachable** from the Nextcloud instance. Ensure that the Elasticsearch service is active and that the configuration settings in Nextcloud are correct to establish a connection.
Good Morning LayLow,
first, thank you for your response!
No, I do not think is a specific Nethserver issue, but i thought, probably anyone under similar conditions could have been confronted with the same. It did not work before so nothing changed. It is not time critical because of personal use only. I am an absolute noob so I hoped for a simple and easy fixable issue :wink:
Nextcloud forums offer several approaches, but I started my search yesterday and for all off them I need more knowledge of how Nextcloud under nethserver works is configured and so on - see above: I am noob!
My System: Rocky Linux 9.7; ns core 3.19.0; 1.6.1 (Nextcloud 33 - Hub 26 Winter);fulltextsearch - elasitcsearchplatform 32.0.2
Thx
maddin
