Thanks. My issue isn’t so much one of docs as a way to test–if you can share API credentials, I’d expect to be able to get OVH support added within a matter of hours. I’d of course recommend you use a fresh key for this purpose, and revoke it once I’m done with it.
Support for OVH has been added, with thanks to @pagaille for the use of credentials used to test it. Released as 0.4.1.
ns8-dnshelper is now in Nethforge at release 0.4.6. If you’ve previously installed it from my repo, you should just be able to update through the software center as usual.
Congratulations!
That’s deserved ! Congrats.
With release 0.5.0, dnshelper will now pick up a PowerDNS instance and any zones it handles, automatically. You’d really want at least a two-node cluster, with both nodes publicly available, to provide redundant DNS.
I just released 0.6.0, and it’s making its way out to Nethforge over the next few hours. This is a major update, turning the Records page into a full-blown DNS record editor. I’d discussed this idea up-thread, but since dnshelper is now the primary frontend for ns8-powerdns, it just became a high priority. ns8-powerdns is the reason this became a high priority, but it works with any DNS provider that dnshelper supports, within the limits of that provider (e.g., only PowerDNS supports PTR records).
Top 5 features of the records editor
- Review before apply. Adds, edits and deletes collect as pending changes, and you see a before/after preview before anything is written. Changes are applied in one go, atomically on PowerDNS.
- Automatic snapshots and revert. The zone is snapshotted before every change, from the admin or another module. You can revert to any snapshot, choosing which changes to undo.
- Per-type forms. MX, SRV, CAA, TXT (with SPF/DKIM hints) and host-name records each get their own fields, so fewer values are malformed. SOA and apex NS are protected.
- Bulk operations and zone files. Change TTLs in bulk, find and replace across values, delete many records at once, and import or export BIND zone files to move a zone between DNS hosts.
- Ownership, PTR and propagation. Each record shows which module wrote it, with a warning before you edit it. Matching PTR records are offered in managed reverse zones, and you can ask the zone’s authoritative name servers whether a change has reached them.
