davidep
(Davide Principi)
March 29, 2024, 5:08pm
61
In NS8 you can remove the last instance, it was just to test…
remove-module --no-preserve roundcubemail3
Then go to NS7 and stop/kill the ns8-bind-app command. Ctrl+C should do the job.
Try to run it again, this time with bash -x, to see what happens:
MODULE_NODE_ID=1 bash -x ns8-bind-app nethserver-roundcubemail
Then, if you like give me SSH access to your NS7, send me a PM.
dan
(Dan)
March 29, 2024, 5:18pm
62
[root@neth nethserver-mail]# MODULE_NODE_ID=1 bash -x ns8-bind-app nethserver-roundcubemail
+ set -e
+ app_id=nethserver-roundcubemail
+ source /etc/nethserver/agent.env
++ PATH=/usr/local/agent/pyenv/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/usr/local/agent/bin
++ AGENT_INSTALL_DIR=/usr/share/nethesis/nethserver-ns8-migration
++ AGENT_STATE_DIR=/var/lib/nethserver/nethserver-ns8-migration
+ source /var/lib/nethserver/nethserver-ns8-migration/agent.env
++ REDIS_ADDRESS=10.5.4.1:6379
++ AGENT_ID=node/2
++ REDIS_USER=node/2
++ REDIS_PASSWORD=0db642da-c27f-4fc5-b4c4-92491723ae4a
+ source /var/lib/nethserver/nethserver-ns8-migration/environment
++ NODE_ID=2
++ USER_DOMAIN=directory.nh
+ app_idir=/usr/share/nethesis/nethserver-ns8-migration/apps/nethserver-roundcubemail
+ app_sdir=/var/lib/nethserver/nethserver-ns8-migration/nethserver-roundcubemail
+ [[ ! -f /usr/share/nethesis/nethserver-ns8-migration/apps/nethserver-roundcubemail/bind.env ]]
+ mkdir -vp /var/lib/nethserver/nethserver-ns8-migration/nethserver-roundcubemail
+ cd /var/lib/nethserver/nethserver-ns8-migration/nethserver-roundcubemail
+ set -a
+ source /usr/share/nethesis/nethserver-ns8-migration/apps/nethserver-roundcubemail/bind.env
++ MODULE_VOLUMES=
++ MODULE_IMAGE_URL=roundcubemail
+ [[ ! -f bind.env ]]
+ source bind.env
++ RSYNC_ENDPOINT=rsync://roundcubemail2@10.5.4.1:20024
++ RSYNC_PASSWORD=1716198affbecd6-19cf-4706-a1b9-4db8d9b4b0de
++ MODULE_INSTANCE_ID=roundcubemail2
++ MODULE_NODE_ID=1
++ IMPORT_TASK_ID=module/roundcubemail2/task/5f669d4f-643a-40ae-b442-8ca3f66559f4
+ set +a
+ rsync -v rsync://roundcubemail2@10.5.4.1:20024/
+ sleep 2
+ sleep 2
+ sleep 2
+ sleep 2
The rsync; sleep2 seems to be repeating indefinitely.
davidep
(Davide Principi)
March 29, 2024, 5:20pm
63
Sorry, you’ve to remove the bind.env file before running that command:
rm -vf /var/lib/nethserver/nethserver-ns8-migration/nethserver-roundcubemail/bind.env
dan
(Dan)
March 29, 2024, 5:26pm
64
There is no bind.env in nethserver-mail (I’d renamed it to bind_env.old, which is where I’ve been running all these commands–but I now see that I should have been in nethserver-roundcubemail all along. Not sure how I made that mistake.
So, I restored bind.env in nethserver-mail, renamed bind.env to bind_env.old in nethserver-roundcubemail, and let’s try again:
[root@neth nethserver-roundcubemail]# MODULE_NODE_ID=1 bash -x ns8-bind-app nethserver-roundcubemail
+ set -e
++ AGENT_ID=node/2
++ NODE_ID=2
+ echo '[ERROR] Unknown app ID nethserver-roundcubemail'
+ exit 1
davidep
(Davide Principi)
March 29, 2024, 5:29pm
65
Right, because the app is named roundcubemail:
MODULE_NODE_ID=1 bash -x ns8-bind-app roundcubemail
My mistake, sorry.
dan
(Dan)
March 29, 2024, 5:30pm
66
[root@neth nethserver-roundcubemail]# MODULE_NODE_ID=1 bash -x ns8-bind-app roundcubemail
+ set -e
+ app_id=roundcubemail
++ AGENT_ID=node/2
++ NODE_ID=2
+ app_idir=/usr/share/nethesis/nethserver-ns8-migration/apps/roundcubemail
+ app_sdir=/var/lib/nethserver/nethserver-ns8-migration/roundcubemail
+ [[ ! -f /usr/share/nethesis/nethserver-ns8-migration/apps/roundcubemail/bind.env ]]
+ echo '[ERROR] Unknown app ID roundcubemail'
+ exit 1
davidep
(Davide Principi)
March 29, 2024, 5:37pm
67
I’m afraid you removed the wrong file.
yum reinstall --noplugins nethserver-ns8-migration
Then remove the bind.env under /var (not /usr)
And (hopefully) that command should do something:
dan
(Dan)
March 29, 2024, 5:52pm
68
Not sure how I would have gotten into /usr/share, but removing the wrong file would certainly explain why things would have broken. The yum reinstall ran without an issue, deleted bind.env in the right place this time, and now the ns8-bind-app ran without an error.
…and following that, “sync data” through the UI also completes without errors for “Email.”
davidep
(Davide Principi)
March 30, 2024, 9:01am
69
Just for the record, I want to say
The UI Abort button does the same. It also tries to remove the NS8 module.
https://docs.nethserver.org/projects/ns8/en/latest/migration.html#migrate-an-application
