No traffic shaping parameters on pppoe interfaces?
NethServer Version: NS7 RC3
I can’t find any way to configure the up and down limits of my (red) pppoe connexion to my internet provider.
Can anyone help ?
Thanks
Matthieu
you should be able to set traffic shaping parameters when you configure a new red interface in Network page. When you select “Internet (red)” as role, traffic shaping text fields should appear in page.
[EDIT] you’re right it’s a bug: you can’t configure traffic shaping on PPPoE interfaces.
The bug is reproducible and has been added to our todo list ( https://github.com/NethServer/dev/projects/2 )
By the way you should be able to do it by hand:
db networks setprop ppp0 FwInBandwidth xxx FwOutBandwidth yyy
db networks set myprovider provider interface ppp0 weight x
signal-event interface-update
Could you please try and report if it works?
Sure. Unfortunaltely it doesn’t look to work. Here is my configuration after having entered the following commands :
[root@mattlabs ~]# db networks setprop ppp0 FwInBandwidth 5000 FwOutBandwidth 5000 [root@mattlabs ~]# db networks set myprovider PROXIMUS interface ppp0 weight 10 [root@mattlabs ~]# signal-event interface-update
[root@mattlabs ~]# db networks show
br0=bridge
    FwInBandwidth=
    FwOutBandwidth=
    bootproto=none
    gateway=
    ipaddr=10.0.1.200
    netmask=255.255.255.0
    role=green
enp0s25=ethernet
    bridge=br0
    role=bridged
enp2s1=ethernet
    FwInBandwidth=
    FwOutBandwidth=
    role=pppoe
myprovider=PROXIMUS
    interface=ppp0
    weight=10
ppp0=xdsl
    AuthType=auto
    FwInBandwidth=5000
    FwOutBandwidth=5000
    Password=*****************
    name=PPPoE
    provider=PROXIMUS
    role=red
    user=************@PROXIMUS
red1=provider
    interface=ppp0
    weight=1
Speedof.me still reports full speed internet. http://speedof.me/show.php?img=170102135409-1825.png
db networks set myprovider PROXIMUS interface ppp0 weight 10 is wrong, correct syntax is db networks set PROXIMUS provider interface ppp0 weight 10
also delete wrong entry with
db networks delete myprovider
Are you sure ? I’m lost here. Looks like things are totally mixed up.
PROXIMUS=provider
    interface=ppp0
    weight=10
br0=bridge
    FwInBandwidth=
    FwOutBandwidth=
    bootproto=none
    gateway=
    ipaddr=10.0.1.200
    role=green
enp0s25=ethernet
    bridge=br0
    role=bridged
enp2s1=ethernet
    FwInBandwidth=
    FwOutBandwidth=
    role=pppoe
ppp0=xdsl
    AuthType=auto
    FwInBandwidth=5000
    FwOutBandwidth=5000
    name=PPPoE
    provider=PROXIMUS
    role=red
    user=********@PROXIMUS
red1=provider
    interface=ppp0
    weight=1
I think you should also delete red1 provider
db networks delete red1
Still no luck. I noticed that the keys FwOutBandwidth and FwInBandwidth aren’t documented in the Traffic Shaping chapter in http://docs.nethserver.org/projects/nethserver-devel/en/latest/gateway.html?highlight=shaping#traffic-shaping :frowning:
Sorry for the waste of time :frowning:
We will work on it, stay tuned.
Stefano is already working on it.
I just opened a new issue, you can follow the progress here:
We have now a package in nethserver-testing:
 yum --enablerepo=nethserver-testing update nethserver-base-3.0.12-1.14.gdb1fb03.ns7.noarch
See also the test cases on https://github.com/NethServer/dev/issues/5187
Continuing the discussion from github (@pagaille):
Maybe is it my testing methodology, but while the UI looks working correctly, I can’t see any effective result
The configuration of inbound and outbound bandwidth doesn’t allow the traffic shaping to cap the network speed. The bandwidth is used to create a buffer used for traffic prioritization.
I suggest you to read the excellent documentation of Shorewall: Complex Traffic Shaping/Control
Then, you can go through out current implementation (Shorewall simple traffic shaping):Simple Traffic Shaping/Control
Thank you very much @giacomo ! It makes sense now. I guess that the idea is to prioritise traffic categories rather than limit others. I was used to the opposite way of doing it like they do on the ClearOS distro.
Exactly :wink:
AFAIK, upload bandwidth is capped precisely, download speed varies around the limit.
