No Login under SOGO
Hi Giacomo,
thanks too! It works.
Regards
Uwe
Package on testing repo fixed the issue on a local AD account provider. :+1:
A quick run on a simple bound NS7 to sambaAD (NS7) worked also.
Sorry for late answer, but today it was like in a beehive…
SOGo-login works like a charme with the testing package.
Installation: RC3, NSDC-Accountprovider, SOGo 3.0.2
Thanks a lot @giacomo ! :+1: :clap: :smile:
Just confirmed it - the new package, nethserver-sogo-1.6.1-1.15.ga5eb638.ns7.noarch.rpm, fixes the bug successfully:
  • If you are running NethServer release 7.3.1611 (rc3) and haven’t installed yet SOGo, don’t use the web interface; instead, as mentioned above use yum and the nethforge-testing repo.
  • If you have already installed SOGo, nethserver-sogo-1.6.1-1.ns7.noarch, running the same yum command will update the package and fix the bug in the sogo.conf file - no restart of the sogod.service required.
yum --enablerepo=nethforge-testing install nethserver-sogo
Actually, the issue was the backslash for the domain name in front of the nethserver name used for the LDAP binding “” that wasn’t escaped (in two places in sogo.conf):
Example:
Old, not working sogo.conf: bindDN = “NEUCHING\JAGERBOX$”;
New, working sogo.conf: bindDN = “NEUCHING\\JAGERBOX$”;
Regards,
Dean
Hi @NetoMeter and welcome here! Your first post has proved to be very useful!
Thanks to your feedback we can release nethserver-sogo-1.6.1-1.15
@mark_nl @giacomo
