on my Mainserver i missed the Field Nethforge in the Softwarecenter after the update from 7.7 to 7.8.
On a other (Virtual) fresh installation with 7.8.2003 image the missed field is inside the Softwarecenter.
it’s the same in the old servermanager.
On fresh installation i can find the the Field NethForge in the old Servermanager.
On updated server i cant find this Field in the old Servermanager.
The update probably disabled the nethforge repository. This because packages in this repository are a community effort not supported by Nethserver ( as in Nethesis the company behind Nethserver).
If you want nethforge enabled anyway you may edit /etc/yum.repos.d/NethForge.repo
and look for enabled=0 in the [nethforge] section change this in enabled=1 EDIT:
keep [nethforge-testing] disabled !
The idea behind the choice of disabling the NethForce repo for subscribed systems was to give the NethServer @support_team fewer variables when diagnosing problems.
Given that after two years the subscription program has not generated a single ticket, we could revise our plan.
Could we allow more “freedom” for subscriptions?
I for instance simply use the subscription as a way of having access to stable/constant updates for production environments & trying to ensure NethServer will be around for some time by paying some $$. Maybe different sub levels have different requirements for your trouble shooting teams, IE Crostino vs. Lasagna on up?
