Just downloaded Centos 7.9.2009 ISO from CERN - in my NAS I still had 7.8.2003…
The NethServer ISO is supposed to be installed on top of Centos 7.9.2009, isn’t it?
have a look at issue tracker, you will find different test cases,
Regarding the ISO for testing you’ll need to use the special-testing one @giacomo linked above…
@djx are you in the position to run a test on a Hetzner VPS?
For you guys - sure :). But I don’t think I can use an ISO, I would just use the install script.
Thank You in advance @djx ![]()
Yes, this is what we are looking for; ![]()
do as you used to do except before running nethserver-install
edit /etc/yum.repos.d/NethServer.repo as I tried to explain above
This will install a (testing) nethserver-base package which should address the network issue you experienced lately.
If you have questions, just ask !
Hi Giacomo
I can confirm that the CD / ISO works as expected in a DHCP environment doing minimal settings at setup. Only Keyboard and root password were set…
All working as expected with Test-ISO
My 2 Cents
IP showed on DHCP server (OPNsense) after installation:
Login works
Console also shows IP:
After login to cockpit:
All as expected!
Now to install Centos7 and install Neth over that from (special) repo …
Install went just fine on Hetzner with the steps listed above.
Thank you (@djx) for testing and the confirmation.
Your post triggered me to dig in to this.
Experienced issues with creation of (Raspberry PI) arm-images for nethserver,
thought it was specific to arm. Turns out not to be so…
Thank you all, I think we verified all test cases!
Great team work and very good fix Mark
Same from here!
Good to read!
(would be bad karma if I broke NS installations today on my 5th year anniversary)
The update has been released
