I did not read the whole thread but did you try to stop the firewall do your test and check if a port is simply not restricted to the green network
shorewall clear
To launch again the firewall
shorewall start
shorewall clear
shorewall start
Alternatively if you need a real webrtc software, you could install jitsy meet on a ubuntu vm, it seems they made a script to ease the installation
Thank you @stephdl for your suggestion. I would have preferred to use apps within Nextcloud but I’ve now tested Jitsi Meet and I’m very impressed with how easy it was to setup! I’m curious why Nethserver hasn’t added Jitsi Meet as a local app for people to use? This appears to be an awesome application and would provide a nice video conferencing option for Nethserver users.
Good point @stephdl. I’ll look at spinning up a jitsi meet server on Ubuntu then on my Proxmox cluster.
it’s really too bad that I can’t get Talk to work on Nethserver. I don’t have firewall enabled on my Nethserver so I can’t figure out why it won’t work? I’ll keep looking into Talk on Nethserver/Nextcloud and hopefully one day figure out the issue. For now I’ll look for another solution in Jitsi Meet.
Thanks!
The right tool makes the right worker.
Firewall is up on any NethServer Instance, even if you have only one green NIC, hopefully ![]()
Hello @stephdl, where in the Nethserver GUI can I adjust firewall settings to open port(s) for Nextcloud Talk? Or even temporarily turn off firewall to see if my Nextcloud works?
Thank you!
Oh boy! Thanks for (re) pointing that out to me! Thanks very much @stephdl
