In the Nextcloud NPM reverse proxy point to https://162.29.49.60:443/nextcloud instead of just https://162.29.49.60:443
Use an internal domain for Nextcloud like cloud.internal.tld and configure NPM to point to https://cloud.internal.tld:443 instead of https://162.29.49.60:443
Did you remove the port forwarding? Did you configure the host to use?
Sorry, I have no idea.
I think it’s a problem with NPM, DNS and the domain names.
Could you provide credentials by direct message so I can check your server later today?
Or I can write another howto including NPM, Nextcloud, onlyoffice and collabora…
I was wondering if there are any updates on this, as i simply installed onlyoffice from nextcloud itself.
I also installed collarbera but i dont see it any where.
!. There are instructions to uninstall collabara using command line above as i dont see it in the list of installed software, should i follow that.
2. Should i uninstall the onlyoffice on nextcloud and follow mrmarkuz guideline in the wiki?
3. I would imagine that there are new versions of everything since this article was written, should i install as per the instructions and update later.
