Hi Giacomo,
i’ve tested on develop environment and it seems solved issue.
I’m waiting for new release availability to upgrade production system.
Please evaluate to upgrade PHP to 7.4 or 8.0 because is needed for future version and check about this NextCloud alert:
** The “X-Content-Type-Options” HTTP header is not set to “nosniff”. This is a potential security or privacy risk, as it is recommended to adjust this setting accordingly.*
** The “X-Robots-Tag” HTTP header is not set to “none”. This is a potential security or privacy risk, as it is recommended to adjust this setting accordingly.*
** The “X-Frame-Options” HTTP header is not set to “SAMEORIGIN”. This is a potential security or privacy risk, as it is recommended to adjust this setting accordingly.*
** Your installation has no default phone region set. This is required to validate phone numbers in the profile settings without a country code. To allow numbers without a country code, please add “default_phone_region” with the respective ISO 3166-1 code
of the region to your config file.*
** You are currently running PHP 7.3.29. Upgrade your PHP version to take advantage of performance and security updates provided by t*
Thanks fo all.
