If we enable Nethserver-Testing and want to install Nethserver-vpn will give the following error:
Available: nethserver-base-2.7.2-1.ns6.noarch (nethserver-updates)
Not found
Available: nethserver-base-2.7.2-1.1.g9d84983.ns6.noarch (nethserver-testing)
Not found
First let’s remove nethserver-vpn if we had already installed
Accessed from ssh
yum remove nethserver-vpn
We disable nethserver-testing repositories
[nethserver-testing]
name=NethServer $distroversion testing
mirrorlist=http://mirrorlist.nethserver.org/$distroversion/nethserver?release=$releasever&repo=testing&arch=$basearch
#baseurl=http://mirror.nethserver.org/nethserver/$distroversion/testing/$basearch/
gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-NethServer-6
enabled=0
enablegroups=1 -
Save the changes
Accessed from ssh
yum update
We left ssh
Now from the software center. select VPN and this will install the following packages:
nethserver-openvpn
nethserver-ipsec
nethserver-vpn
there is a conflict between: nethserver-base-2.7.2-1.ns6.noarch & nethserver-base-2.7.2-1.1.g9d84983.ns6.noarch
Regards
