Hi folks ive seen a few threads on this subject but am a little confused so a simple answer appreciated - what versions of php can i run on Nethserver v7 - im looking to run drupal8 so i think i need to be php5.6 or above but would normaly run php7 if its achievable. Any suggestions appreciated!
Cheers
Alex
Hi @alpreseidente,
I recommend using the PHP-scl module. You may easily choose your php version via web UI.
