Nethserver squid customization
# at NethServer official site: https://www.nethserver.org
# Uncomment this to enable debug
#debug_options ALL,1 33,2 28,9
# Sites not cached
acl no_cache dstdomain "/etc/squid/acls/no_cache.acl"
no_cache deny no_cache
# Allow access from green and trusted networks.
acl localnet src 192.168.0.0/17
acl localnet_dst src 192.168.0.0/17
# Safe ports
acl SSL_ports port 443
acl SSL_ports port 980          # httpd-admin (server-manager)
acl SSL_ports port 9090         # Cockpit Web UI
acl Safe_ports port 80          # http
acl Safe_ports port 21          # ftp
acl Safe_ports port 443         # https
acl Safe_ports port 70          # gopher
acl Safe_ports port 210         # wais
acl Safe_ports port 1025-65535  # unregistered ports
acl Safe_ports port 280         # http-mgmt
acl Safe_ports port 488         # gss-http
acl Safe_ports port 591         # filemaker
acl Safe_ports port 777         # multiling http
acl Safe_ports port 980         # httpd-admin (server-manager)
acl CONNECT method CONNECT
# 20acl_00_portscustom
acl Safe_ports port 8008
acl SSL_ports port 8008
acl Safe_ports port 8443
acl SSL_ports port 8443
acl Safe_ports port 8080
acl SSL_ports port 8080
acl Safe_ports port 5001
acl SSL_ports port 5001
acl Safe_ports port 5000
acl SSL_ports port 5000
acl Safe_ports port 8006
acl SSL_ports port 8006
acl Safe_ports port 9090
# Authentication required
# GSSAPI auth in ADS mode
auth_param negotiate program /usr/lib64/squid/negotiate_kerberos_auth -i
auth_param negotiate children 10
auth_param negotiate keep_alive on
# BASIC PAM auth (fallback)
auth_param basic program  /usr/lib64/squid/basic_pam_auth
auth_param basic children 5
auth_param basic realm hydrosila.com
auth_param basic credentialsttl 1 hours
auth_param basic casesensitive on
acl authenticated proxy_auth REQUIRED
# exclude localhost from logging
# these lines have to go before any logging acl
access_log none to_localhost
# 20acl_95_localnet_log
# Make sure logs go to access.log
# Put custom logging config above this section
access_log daemon:/var/log/squid/access.log squid localnet
# Allow access from localhost
http_access allow localhost
# Deny requests to certain unsafe ports
http_access deny !Safe_ports
# Deny CONNECT to other than secure SSL ports
http_access deny CONNECT !SSL_ports
# Only allow cachemgr access from localhost
http_access allow localhost manager
http_access deny manager
# Skip URL rewriter for local addresses
acl self dst 192.168.12.78
acl self_port port 80
acl self_port port 443
url_rewrite_access deny self localnet  self_port
# Authentication required on green and trusted networks
http_access allow localnet authenticated
# And finally deny all other access to this proxy
http_access deny all
cache_mem 256 MB
# Leave coredumps in the first cache dir
coredump_dir /var/spool/squid
# Add any of your own refresh_pattern entries above these.
refresh_pattern ^ftp:           1440    20%     10080
refresh_pattern ^gopher:        1440    0%      1440
refresh_pattern -i (/cgi-bin/|\?) 0     0%      0
refresh_pattern .               0       20%     4320
refresh_pattern ([^.]+.|)(download|(windows|)update|).(microsoft.|)com/.*\.(cab|exe|msi|msp) 4320 100% 43200 reload-into-ims
# Always enable manual proxy
http_port 3128
acl https_proto proto https
always_direct allow https_proto
ssl_bump none localhost
sslproxy_options NO_SSLv2,NO_SSLv3,No_Compression
sslproxy_cipher ALL:!SSLv2:!ADH:!DSS:!MD5:!EXP:!DES:!PSK:!SRP:!RC4:!IDEA:!SEED:!aNULL:!eNULL
# TLS/SSL bumping definitions
acl tls_s1_connect at_step SslBump1
acl tls_s2_client_hello at_step SslBump2
acl tls_s3_server_hello at_step SslBump3
# TLS/SSL bumping steps
ssl_bump peek tls_s1_connect all
ssl_bump splice all
# peek at TLS/SSL connect data
# splice: no active bumping
# 45marks
# Enable squidGuard
url_rewrite_program /usr/sbin/ufdbgclient -l /var/log/squid
url_rewrite_children 20 startup=5 idle=5 concurrency=0
url_rewrite_extras "%>a/%>A %un %>rm bump_mode=%ssl::bump_mode sni=\"%ssl::>sni\" referer=\"%{Referer}>h\""
# 90options
forward_max_tries 25
shutdown_lifetime 1 seconds
buffered_logs on
max_filedesc 16384
logfile_rotate 0
Looks OK, as far as I can see…
The computer is fine!
I got the impression that the filters are working but somehow not correct
Namely, I created three filters and specified different rules for each AD group. But everyone who belongs to one of the groups behaves differently !!! I remind you that the filters are applied to users, and not to specific computers
For example, in the filter, I set up to block the selected categories (all available) when adding a user to the AD group which is involved in this filter - nothing happens !!
