you run docker on 127.0.0.1:9000 it is normal that you cannot reach it
what is the output of
config show docker
config show docker
docker=service
TCPPort=9000
access=red,green
status=enabled
please
# db networks show
eth0=ethernet
bootproto=none
gateway=104.167.5.1
ipaddr=104.167.5.181
netmask=255.255.255.0
role=green
ppp0=xdsl-disabled
AuthType=auto
FwInBandwidth=
FwOutBandwidth=
Password=
name=PPPoE
provider=xDSL provider
role=red
user=
your red nic is a dummy one, look you have no ipaddr property attached, you must use in this case the green nic
at the end, your use case let me think we need a specific panel for this
Yeah that was the issue. Removed red and it works. Thanks
maybe I miss understood the question but the only parameter I ever pass the grub/kernel is to limit the swap cgroup_enable=memory swapaccount=1 and as you could presume it’s more related to cgroup than username space
@davidep, @stephdl @dev_team if I build (rebuild) a Nethserver and add some specification for docker would you consider it to be into the prod version ?
because for me offering something secure by default is offering an easier life for the user.
welcome back ![]()
Yes for sure we want to offer something secure by design, but for now the focus is to create the tool and also the next needed when you use docker : a reverse proxy that I hope it will be traefik
As I said we need inputs of all sysadmin or skilled people, the matter to write the code of a good howto is easy and quick.
maybe because it was not a centos7 OS ???
Hi @stephdl I installed
My green network is 192.168.122.0/24 (libvirt NAT). I’m looking at
[root@vm5 ~]# config show docker
docker=service
TCPPort=9000
access=green
status=enabled
And in nethserver-portainer_container action
/usr/bin/docker run -d -p 9000:9000 ... portainer/portainer
Also the systemd drop-in /etc/systemd/system/docker.service.d/nethserver.conf
ExecStart=/usr/bin/dockerd --ip 192.168.122.5
…well I want to propose an alternative approach for iptables and port forwards: there can be another solution to access portainer web UI, let’s discuss it!
--iptables=false to dockerd: we push iptables rules explicitly, by defining them in templates and from firewall UI (we can define a custom firewall zone in the future). We can also disable shorewall flag for Docker chains with this configuration.https://IP:980/portainer
With this approach docker cannot allocate IP addresses for us: I need to reason about this a bit…
In this case, when you create a container, then you might need a human intervention to create the firewall stuff with a panel in nethgui…not sure it is nice
For all other relative ideas to portainer, yes…
I have something wrong with what I did.
Docker runs on all available interfaces of the server, it means 0.0.0.0. Of course I do not want that all containers are reachable by their TCP ports from everywhere, I want to decide on what interface/zone docker launch its containers.
For facility/efficiency we launch dockerd with --ip xxx.xxx.xxx.xxx however to change the ip we use the network service panel, but sometime we have a red (false) nic and it can mislead the sysadmin…hence if we still go in this direction we need a tiny panel.
Another thing that probably needs an UI in the future is the storage configuration. The default devicemapper configuration is not recommended in production, instead a block device has to be allocated for the direct-lvm mode (see Device Mapper storage driver (deprecated) | Docker Docs).
About --ip I’m studying the Docker networking a bit to see if we have an alternative…
Ok, I pushed my experiment here (branch portainer), a README and a bunch of config files.
https://github.com/DavidePrincipi/nethserver-docker/blob/portainer/README.rst
My proposal is to disable the default Docker behavior that mangles iptables configuration, and requires a special Shorewall configuration to work properly in NethServer. Instead, all the Firewall plumbing happens with esmith templates and DB values.
Furthermore the prototype above defines a dedicated docker network, associated to a firewall zone: aqua. The first impression from the sysadmin point of view is to act with aqua like a green zone with some hosts in it. Please read the README.rst file for more info.
Another successful experiment is using a dedicated block device, as recommended by Docker official docs.
Now I have to test if traefik is really useful for us. It can auto-configure the reverse-proxy routes by reading them from containers metadata, which is really cool. Furthermore it is a real reverse-proxy, for large sites, with load balancing, health checks and automatic failover… But I can also drop traefik and configure Apache as reverse proxy too
Special thanks to @giacomo for helping with Shorewall and @stephdl for his starting point!
traefik is a huge software, I thought to get two ways to configure it, by the [docker] configuration (by labels) like you spoke, but also by the [file] configuration for vhost we have in apache (we have to change the tcp 80 and 443 port of apache if we want to start traefik)
Bear in mind that you have in the portainer interface, an url link to use the port of the container, it could be nice to get it workable
I mean about this FAQ — Portainer 1.23.2 documentation
Yes, the “label” way works and is really straightforward
Just add a label from Portainer UI (Docker --label option from CLI) to instruct Traefik properly
The prototype above relies on firewall port forwarding rules for port 80 and 443 to override the main Apache instance and direct IP packets to Traefik. Surely every application that runs a real backend service, like WebTop, Mattermost, Nextcloud can push their rules into [file] to bypass Apache and optimize HTTP(S) traffic hops.
My impression is we do not need the “Published Ports” link in real cases (see image below). The link works only for HTTP, if the container exposes a web server. But web traffic is already handled by a reverse proxy (like Traefik). If the container exposes some other service (for instance a database server) the link is useless!
What did we achieve so far and where to go? Just some thoughts…
Docker integration with Shorewall. Defining the aqua network leads to a situation that can be easily handled with existing Firewall interface, from Server Manager. We need a wizard procedure that creates the firewall objects automatically.
Docker dedicated block device storage: requires an UI to select it (wizard procedure)
Portainer is a nice web UI, tailored on the docker CLI. I think most docker options are trasposed to the UI, so it is really powerful but quite complex. One must know well Docker to operate Portainer. BUT there’s the “Application templates” feature that is really promising for me!
Traefik is a real reverse proxy. It’s flexible, it has a configuration file and also an HTTP API for configuration. It can auto-configure itself by reading the container labels (set by a Portainer app-template) from Docker: it’s perfect for it. However, its web UI is read-only, so we are still lacking a complete UI to configure it as reverse proxy for services running in another (LAN) host.
@stephdl what is the second package ?
this is still the right way to install it ?
we would test a new way for docker, do not use TCP port but internal IP for container, still WIP
I am running portainer on ssl see here https://login.genius.ke:9000
and it all seems to be working fine.
and how come I never knew this was there, its a very nice effort.
whats the plan with regards to fully intergrating it in nethserver. will it be in the software center.
this location for Jenkins password is not there v
/var/jenkins_home/secrets/initialAdminPassword
I just pushed an RPM to nethforge-testing, based on the previous Portainer prototype.
The source code is now an official NethServer repository, please have a look at the README here: https://github.com/NethServer/nethserver-docker/blob/master/README.rst.
yum --enablerepo=nethforge-testing install nethserver-docker
In short:
aqua Shorewall zone is defined and created automaticallyJust for our experiments, I configured mysql port 3306 open from aqua
Now what I can’t still grasp is the container upgrade and backup/restore lifecycles. I need to do some tests and study the latest Docker features to get an idea for them…
ideas are welcome!
