Delete database files:
rm -rf /var/opt/rh/rh-mariadb103/lib/mysql/*
Remove mariadb103 including nethserver-mariadb:
yum remove "*mariadb103*"
And how to remove the âmoodle-version-mixâ?
yum remove nethserver-moodle?
or do you think it is bettter to give a re-install of mariadb103 a try following @stephdl procedure?
Yes, itâs a mariadb103 issue as default databases were not created.
Removed mariadb103, reinstalled it according to
https://wiki.nethserver.org/doku.php?id=mariadb103
stopped service
Deleted all datĂĄbases
re-installed all databases
re-installed moodle database
restart service
â no succcess, same behavior as before.
Some files may need to be removed manually (changed config files etc.)
To get files/dirs of a package:
rpm -ql rh-mariadb103-mariadb-server
Maybe fire up a VM and install mariadb103 to compare.
This ist to dangerous 4 me:
The list contains e.g. the directory:
/var/lib/mysql
This directory does contain the db files of the regular SQK installation. Obviously, it must not be deleted.
Lets do it vice versa:
The command
find -iname *mariadb103* > /var/lib/nethserver/ibay/public/mariadb103-relicts.txt
looks for files containing mariadb103. Its output is:
I send the output from
to a file, too. The outpout is here
Any line in the latter contains the string âmariadb103â except of one line:
/var/lib/mysql
Can you countercheck the ârelicts-fileâ if these are only relicts, pls?
Can you you confirm that the mysql-file-list.txt does (except the line above) contain files for mariadb103?
TIA
Thorsten
Sorry, I donât know which files exactly are needed to solve the issue. You could move the files away instead of deleting them or try it in a snapshotted VM and delete everything.
