Nethserver Crash?
My customer call me because has no internet i check /var/log/messages and there’s a gap of an hour
as you can see on the screenshot below:
Is mean the Centos Crash/Block?
Thanks :slight_smile:
Hello, what CPU does the box mount?
looks like “another” evebox (Suricata!) issue. In your log (6 lines above / higher than the first red marked line) it says there’s no EOF in a logfile?
A few lines earlier, you have a SSH access form a ubuntu user?
System hacked?
PS:
Suricata seems to cause a lot of errors, not only here!
I think that the evebox log about overload may be a symptom of… overload, but we can’t know what caused overload.
You may enable kdump and analyze it after another crash.
Apu2 bios seems… stale. 2019?
According to PC Engines - github pages, latest bios release for this board computer seems February 2023.
I’d consider a help.
Also: 140mb of log dump. With 96mb allowed, considering what reported on log.
Thanks for the reply, i think i upgrade the firewall with another hardware.
You’ll hardly find something so energy efficient.
