Hello everyone,
I want to know a thing about operating nethserver, in particular authentication.
When I install the mail, owncloud and groupware, user authentication is centralized? or I can get in the mail and groupware owncloud in using the same credentials?
thank you
Yes it is.
All applications uses the same authentication system.
But regarding Owncloud, if you want, you can also create users which can only access Owncloud itself.
