I am evaluating the scenario of using nethserver+freepbx as a UC solution. In many cases, telephony cards will be needed for connecting to a TSP instead of SIP Trunks?
Is this possible with nethserver? Are telephony cards supported? What driver should I use?
Regards,
Hi @torrio,
welcome to NethServer community.
Nethserver is based on centos which is recommended and widely used as base system for freepbx based distros so it should support telephony cards. Which card do you have?
https://wiki.freepbx.org/display/PC/Telephony+Cards+for+Asterisk
I guess @alep and @Stll0 can give some help here.
AFAIK we don’t support any internal card, but we usually install external gateways like https://www.patton.com/voip-gateway/.
digium cards for BRI works, but as Giacomo said, we usually install external gateways like Patton or Sangoma https://www.sangoma.com/products/voip-gateways/
Hi, can someone please tell me how to solve this:
Did you install additional freepbx modules?
Please check if the mail address under “Admin/Module Admin” is correct:
Maybe you can find some errors in /var/log/maillog.
Jun 25 18:38:02 hostname postfix/pickup[26861]: 151F3C0000B30: uid=983 from=<asterisk>
Jun 25 18:38:02 hostname postfix/cleanup[24046]: 151F3C0000B30: message-id=<20180625163802.151F3C0000B30@hostname.domain.lan>
Jun 25 18:38:02 hostname postfix/qmgr[10824]: 151F3C0000B30: from=<asterisk@hostname.domain.lan>, size=1097, nrcpt=1 (queue active)
Jun 25 18:38:02 hostname dovecot: lmtp(27060): Connect from local
Jun 25 18:38:02 hostname postfix/lmtp[23732]: 151F3C0000B30: to=<asterisk@hostname.domain.lan>, orig_to=<asterisk>, relay=hostname.domain.lan[/var/run/dovecot/lmtp], delay=0.05, delays=0.02/0/0/0.03, dsn=5.1.1, status=bounced (host hostname.domain.lan[/var/run/dovecot/lmtp] said: 550 5.1.1 <asterisk@hostname.domain.lan> User doesn't exist: asterisk@hostname.domain.lan (in reply to RCPT TO command))
Jun 25 18:38:02 hostname dovecot: lmtp(27060): Disconnect from local: Successful quit
Jun 25 18:38:02 hostname postfix/cleanup[24046]: 2038EC00030EC: message-id=<20180625163802.2038EC00030EC@hostname.domain.lan>
Jun 25 18:38:02 hostname postfix/bounce[26852]: 151F3C0000B30: sender non-delivery notification: 2038EC00030EC
Jun 25 18:38:02 hostname postfix/qmgr[10824]: 151F3C0000B30: removed
I got the same errors in maillog but not the error in the dashboard.
It seems like asterisk wants to send to asterisk@hostname.domainname but the users just have @domainname so user asterisk@hostname.domainname is not found.
I have to investigate further…
If you click on the error message you should see error details like “An attempt to send an email to … with security notifications failed”.
I had similar message now. When you just install freepbx but do the first config wizard later it’s sending an email to “” in the meanwhile:
