@dz00te would you like to add it on our NethForge? @giacomo @davidep how can we move forward?
I’ve been watching this thread for some time, this package does something very similar to that of a shell script/daemon I wrote. But my shell script/daemon takes it a step further; when it recognizes a new device on the network (not within a open DHCP range) is adds the IP/MAC address to available linux firewalls on the network. This is the default setup, I can change the sensitivity to be strict it would add the IP/MAC address of a newly discovered device in the open DHCP range to the firewalls. The script must have sudo access of course because iptables command requires it, it also must be able to login to other linux boxes without a SSH password.
Adding IP addresses on Linux firewalls is relatively simple but finding a way to do this on NethServer was challenging. Instead I opted to use MAC addresses. In order to do that I needed to create a custom template for shorewall where the BLACKLIST option changed to “NEW,UNVALID,UNTRACKED” so that I can dynamically add and remove the MAC’s.
The shell script/daemon consists of three files, a configuration file, daemon and shell commands itself. If anyone is interested in looking at the concept I can certainly upload it to github. It may take some time because I’d have to remove a number of personal settings.
@alefattorini
honestly… i don’t remember what i miss to finish the package, i’ll check it and will update the status soon. And, yes if ever will be finished/stable, the idea is to put it on netforge, but i must admit that lately in my short time available, ns7alpha has an high priority
@islipfd19
nice idea, if i ever finished the package i’ll ask you the script, tnx
@islipfd19 as we have introduce fail2ban we can make things work through it
Great idea! I’m thinking some type of trigger from arpwatch to fail2ban to blacklist the offending MAC/IP address and then a way to whitelist it after additional review.
I failed to mention that my shell script also sends notifications using the any of the mail apps; such as postfix or sendmail. As long as its configure properly of course. My shell script also has a mechanism to whitelist the MAC/IP address; CLI driven. Again, my script detects any unknown IP/MAC on the local network. At the heart of the script is nmap that performs a ping sweep of the network and grabs all the MAC addresses, compares them to a predefined list of MAC’s in it’s configuration file and the list of MAC’s obtained from the DHCP config file. When time permits I’ll upload it to github.
When the author think the packages is finished, we can move it to the forge.
We can also give access directly to the forge
@islipfd19 please attach log, I have created an issue on Fail2ban so they could help to develop arpwatch log monitoring.
I don’t have a log, there may have been some confusion. I currently don’t use Fail2ban or arpwatch, the script I’m referring to is something that I designed and wrote. I believe it would be a “Nice to have” feature for both.
updated version on first post…
I left it too long, i remember that there was something i want to change/check but i don’t remember what… ![]()
so for now:
- after install, the service is enabled and configured on all eth on green
- it should work also with multiple eth
- mail is sent by default to root
still to do:
- implement a script to update ethercodes.dat using Sanitized IEEE OUI Date (oui.txt) (or put it in the file to separate rpm, or … honestly i’m not sure at the moment how to do but i would like to have it updated :))
- a gui (???) if i will ever complete points 2 and 3
and a lot of testing ![]()
Though this isn’t part of nethserver, its suppose to assist with the ideas and I’m just replying to a post I placed a month ago.
So I finally got around to uploading my netsecure daemon to github for public use. I’ve named it netsecure for the moment, I may decide to change it in the future. It contains a daemon, configuration file and script itself at the heart of the program. It uses nmap and sendmail (or a similar program). Its purpose it to catch new/foreign mac addresses on your local network and add them to the local firewall and any other firewall (or shorewall) running on a different *nix box.
Any suggestions or questions are welcome, even bugs; I’ll help where I can.
on ns7alpha2 (x86-64 and ARM)
yum install http://mirror.framassa.org/dz00test/nethserver-arpwatch-1.0.0-2.ns7.noarch.rpm
I think that no one uses this contrib (neither me
)… but just for information, there are problems with multiple eth on NS7, i’ll try to fix it
that’s it… a quick and (probably) dirty fix for systemd with multiple eth… while centos do not support multple eth for arpwatch, the solution was to use a systemd template unit and instance it for the various eth.
The problem is that i can’t succeed to use services2adjust anymore… ![]()
(it looks for a arpwatch.service instead of arpwatch@ethX)
probably i need more time to study NethServer::Service and esmith::events ![]()
so for now, after a changes to eth config a
signal-event nethserver-arpwatch-update
is needed
new link for tests on ns7
yum install http://mirror.framassa.org/dz00test/nethserver-arpwatch-1.0.0-3.ns7.noarch.rpm
edit:
added restart option to systemd unit template… maybe not a great solution but it seems to work. updated also the file on mirror…
You can now install it from nethforge-testing!
yum --enablerepo=nethforge-testing install nethserver-arpwatch
Don’t be sad like this module
you should describe some interesting use scenarios to attract more users!
yes, i will do, but this is a quite specific module and not widely used today… not much useful without a gui for the report, well at least now there is a basic gui for the config…
as always tnx to master (@stephdl) as most of code was adapted from ddclient gui ![]()
new link (only ns7)
http://mirror.framassa.org/dz00test/nethserver-arpwatch-1.0.0-4.ns7.noarch.rpm
this is what free software is supposed to be :), happy to contribute to that !
Hi Folks,
Sorry to bring this back from the dead.
This .rpm is no longer available.
This is a really neat project.
Does anyone kept the package?
Thanks,
@dz00te can u help here
