Nethserver 8 and Contabo
I think it’s time to try Nethserver 8 on a public server. I was thinking of using Contabo Cloud VPS 6 for testing. https://contabo.com/en/vps/
Does anyone have experience with Contabo VPSs?
Is it compatible with Nethserver 8?
Is Contabo Cloud VPS 6 enough to serve 6-8 users simultaneously?
Unfortunately, the storage space is limited, but they recommend Object Storage as an Add-on instead. Does anyone know about this? Can it be used safely with Nethserver 8? Maybe as a Samba share with https?
Thank you for your help
Yes
Contabo is great am currenlty using Nethserver 8 with Rocky Linux and its working very well on my end
You can check this thread and get more info
:slight_smile:
I’ve been using them for several years, including with NS7 and NS8.
How much storage do you need, and what for? I’d consider the “object storage” (i.e., S3-compatible storage) useful for backups, but not if you need online storage.
@kemboielvis22 Thank you for sharing your experience and the link, both are very useful.
@dan Thank you for sharing your experience.
It would be needed as a Samba share, because the VPS storage space would be limited. But I don’t think it’s really recommended for this purpose. Maybe I should look at a bigger package…
That’s probably the best plan.
