NethServer 7.5.1804 rc released
RC has come! (re)read the release notes
Release notes 7 — NethServer 7 Final
Links:
Hashes
  • md5 82a4357c7fc8f0d9a331975ded7048a8
  • sha1 278f03bd56cba9049ba26ea3cfc34d60a9a04b48
Torrent
Please, help @alefattorini and @davidep to write the Collaborative draft of 7.5 release announcement
Here’s a Dashboard screenshot!
Others screenshots with NS 7.5.1804 rc!
can i upgrade from the beta of 7.5.1804?
Regards
Uwe
Hi Uwe,
Yes, I did the upgrade from Software Center.
Look at the first screenshot from above.
Hi Gabriel,
there is no update available.
Upgraded to 7.5.1804 rc and seems all it’s working.
What is your version now?
Hi Federico,
System Version:
NethServer release 7.5.1804 (beta)
Kernel 3.10.0-862.3.2.el7.x86_64
Ok. I confirm that I have updated from 7.5.1804 (beta) to 7.5.1804 rc from Software Center…
If you have #subscription it is still not available.
If not, run
 yum clean all
Or wait until your local metadata cache expires
 yum repolist -v
Gives all the info you need
Hi Davide,
here is the output of yum repolist -v
Loading “changelog” plugin
Loading “fastestmirror” plugin
Loading “nethserver_events” plugin
Config time: 0.010
Yum version: 3.4.3
Setting up Package Sacks
pkgsack time: 0.008
Repo-id : sb-base/x86_64
Repo-name : Stable mirror: CentOS Base 7
Repo-revision: 1525378614
Repo-updated : Thu May 3 22:17:37 2018
Repo-pkgs : 9,911
Repo-size : 8.2 G
Repo-mirrors : https://mirrorlist.nethserver.com/?repo=base&arch=x86_64&nsversion=7.5.1804&usetier=$YUM0
Repo-baseurl : https://m1.nethserver.com/stable/7.5.1804/base/x86_64/
Repo-expire : 7,200 second(s) (last: Thu May 31 21:10:32 2018)
Filter : read-only:present
Repo-filename: /etc/yum.repos.d/subscription.repo
Repo-id : sb-centos-sclo-rh/x86_64
Repo-name : Stable mirror: SCLo rh 7
Repo-revision: 1526298601
Repo-updated : Mon May 14 13:51:55 2018
Repo-pkgs : 7,050
Repo-size : 6.2 G
Repo-mirrors : https://mirrorlist.nethserver.com/?repo=centos-sclo-rh&arch=x86_64&nsversion=7.5.1804&usetier=$YUM0
Repo-baseurl : https://m1.nethserver.com/stable/7.5.1804/centos-sclo-rh/x86_64/
Repo-id : sb-centos-sclo-sclo/x86_64
Repo-name : Stable mirror: SCLo sclo 7
Repo-revision: 1526296152
Repo-updated : Mon May 14 13:09:15 2018
Repo-pkgs : 521
Repo-size : 109 M
Repo-mirrors : https://mirrorlist.nethserver.com/?repo=centos-sclo-sclo&arch=x86_64&nsversion=7.5.1804&usetier=$YUM0
Repo-baseurl : https://m1.nethserver.com/stable/7.5.1804/centos-sclo-sclo/x86_64/
Repo-id : sb-epel/x86_64
Repo-name : Stable mirror: EPEL 7
Repo-revision: 1526477138
Repo-updated : Wed May 16 15:44:12 2018
Repo-pkgs : 12,542
Repo-size : 13 G
Repo-mirrors : https://mirrorlist.nethserver.com/?repo=epel&arch=x86_64&nsversion=7.5.1804&usetier=$YUM0
Repo-baseurl : https://m1.nethserver.com/stable/7.5.1804/epel/x86_64/
Repo-id : sb-extras/x86_64
Repo-name : Stable mirror: CentOS Extras 7
Repo-revision: 1526062886
Repo-updated : Fri May 11 20:22:45 2018
Repo-pkgs : 258
Repo-size : 428 M
Repo-mirrors : https://mirrorlist.nethserver.com/?repo=extras&arch=x86_64&nsversion=7.5.1804&usetier=$YUM0
Repo-baseurl : https://m1.nethserver.com/stable/7.5.1804/extras/x86_64/
Repo-id : sb-nethserver-base/x86_64
Repo-name : Stable mirror: NethServer Base 7
Repo-revision: 1526561030
Repo-updated : Thu May 17 14:43:56 2018
Repo-pkgs : 288
Repo-size : 1.0 G
Repo-mirrors : https://mirrorlist.nethserver.com/?repo=nethserver-base&arch=x86_64&nsversion=7.5.1804&usetier=$YUM0
Repo-baseurl : https://m1.nethserver.com/stable/7.5.1804/nethserver-base/x86_64/
Repo-id : sb-nethserver-updates/x86_64
Repo-name : Stable mirror: NethServer Updates 7
Repo-revision: 1526560996
Repo-updated : Thu May 17 14:43:17 2018
Repo-pkgs : 0
Repo-size : 0
Repo-mirrors : https://mirrorlist.nethserver.com/?repo=nethserver-updates&arch=x86_64&nsversion=7.5.1804&usetier=$YUM0
Repo-baseurl : https://m1.nethserver.com/stable/7.5.1804/nethserver-updates/x86_64/
Repo-id : sb-updates/x86_64
Repo-name : Stable mirror: CentOS Updates 7
Repo-revision: 1526479129
Repo-updated : Wed May 16 16:00:23 2018
Repo-pkgs : 151
Repo-size : 979 M
Repo-mirrors : https://mirrorlist.nethserver.com/?repo=updates&arch=x86_64&nsversion=7.5.1804&usetier=$YUM0
Repo-baseurl : https://m1.nethserver.com/stable/7.5.1804/updates/x86_64/
You have a Subscription!
We don’t have planned to fast track this release by now. The standard schedule will make it available in 10-15 days
See also
Updated from 7.4.1708 version, everything seems ok
