Thanks for reporting and happy that you like it /cc @stephdl
is selfhost.eu supported?
I also created an account on hn.org but I donât know what I have to put into the fields in the ddclient module (especially the login name I donât know)⊠Could you help me please?
no specific clue, generally speaking , the login+password fields are the login name+password of the dynamic dns provider web site
reading this, these are the mandatory fields, in bold what you need to adjust
protocol=dyndns2
server=carol.selfhost.de
login=ihr_dyndns_account
password=ihr_passwort
Thanks!!! works great!!! perhaps you could add selfhost in the list of official providers!??
available for ns6 and ns7
Hi Stephane;
I just install ddclient from youâre repository
It is normal it didnât include perl-JSON-Any in the installation ?
[UPDATE]
Now with CloudFlare you need to specify the zone=
so in the ddclient.conf, just after protocol=cloudflare,
at the end you have something like
server=www.cloudflare.com, \
protocol=cloudflare, \
zone=domain.tld, \
login=email@youusewithcloudflare.com, \
password=GlobalAPI \
subdomain.domain.tld
would be awesome to add the zone option
so in this way Cloudflare will become an Official Providers
Which version of ddclient and ns server you use ?
Nethserver 7
ddclient version 3.8.3
installed from : http://wiki.nethserver.org/doku.php?id=module:ddclient
thanks @JOduMonT I misunderstood your issue. In fact to use the cloudfare.com provider you need several things
perl-JSON-Any
new entries in the templates/nethgui
specified zone (I suppose it is the dynamic domain ???)
login (email address)
password (api-key/GlobalAPI ???)
I would try to offer this option in the netgui, but I donât want to waste my free time to offer forum support if the options are not clear
Can you please explain me a bit more where the settings can be found ?
hum!
might be because iâm a french native but maybe I missunderstood your question âŠ
so if my bash_history is good
after a bunch of try I finally just add
yum install perl-JSON-Any
than install ddclient from your repo
and in /etc/ddclient.conf I use with success
daemon=600 # check every 600 seconds
syslog=yes # log update msgs to syslog
mail=my@email.tld # mail update msgs to root
mail-failure=my@email.tld # mail failure msgs to root
pid=/var/run/ddclient/ddclient.pid # record PID in file.
ssl=yes
use=web, web=ip.changeip.com/
zone=myDomainName.tld, \
login=myemail2login@cloudflare.com, \
password=MyAPIPassword \
machine1.domain.tld, machine2.domain.tld \
machine3.domain.tld, machine4.domain.tld
cloudflare seems only works with ip.changeip.com
could you please test this version with cloudflare embedded
yum install http://mirror.de-labrusse.fr/NethDev/nethserver-ddclient/nethserver-ddclient-1.0.3-1.ns7.sdl.noarch.rpm
thanks for your fast and nice works, iâll try soon and give you a feedback
You should pay him a as well
On my first try it didnât works
no update on my ip
the config looks fine
iâll investigate a little bite more and keep you in touch
look after logs
## CloudFlare (www.cloudflare.com)
#protocol=cloudflare, \
#zone=domain.tld, \
#server=www.cloudflare.com, \
#login=your-login-email, \
#password=APIKey, \
#ttl=1 \
#domain.tld,my.domain.tld
try to add âttl=1â and report please
Sorry; I had others cats to whip
So basicly the installation works
the issue is the zone parameter
when iâm using the NethSever WebUI to define my account
the zone in the /etc/ddclient.conf
will be define with my subdomain.domain.tld
instead of domain.tld
if I change this line in the file and restart ddclient
Everything works perfectly
I didnt have to use change any others parameters
zone=domain.tld,
password=APIKey,
domain.tld,my.domain.tld,other.domain.tld
please reinstall the rpm, it should be good
