These are the (public) dns servers for resolving external (website) requests
Here you can set dns records for local serveries / websites which do not have a dns record in the (external) public dns servers.
For proper operation of a local installed nethserver AD it is highly recommended (almost mandatory) this server is the DNS/DHCP server for the local-network too.
Yes, After you set an fixed IP for the green interface you plan to be the local DNS/DHCP server, you need to provide a (second) fixed IP address for the AD in the same network-range during the installation of the AD.
The installation process creates a bridge, assigns the IP addresses and takes care of the local DNS settings. Note: it’s possible to change host-name of the server and domain-name after provisioning of the AD, choose them wisely.
Above being said I usually (virtual) disconnect the NIC planed to provide the (new) local DHCP/DNS server from the existing local network. This way you can start the DHCP/DNS before installing the AD without messing up the local-network. This is not mandatory, just seem to have the most smooth installation this way…
It’s still not clear to me. Sould I define the static IP from the AD for local requests? Would this cover the config setprop dnsmasq DomainRedirection? If so, why set a config setprop from the cli?
Or do I need for AD always the redirection from the cli?
edit: in case of the redirection would the command be:
FQHN:IP of NS, FQHN:IP of AD Container ?
Set a fixed IP for the NIC which will be the future local DHCP/DNS
optional if possible configure and start the DHCP/DNS server on this NIC < NOTE you do not want two DHCP servers in your local network hence it’s better to (virtually) disconnect this NIC
go to System > Users and install local AD, when asked for an IP it must be in the same range as the IP of the above mentioned NIC
