NethServer release 7.3.1611 (Final)
Basic firewall
I’m trying to configure Multi Wan in balanced mode.
But from what I can see I’m only using one of the two connections.
curl ‘https://api.ipify.org?format=json’
{“ip”:“93.65.5.66”}
gives always he same result (from the server and from different clients).
If I unplug one of the two wan cables then I can see the traffic switching on the other ISP.
ip route show table balance
default
nexthop via 93.65.5.65 dev p1p1 weight 100
nexthop via 89.95.210.81 dev p4p1 weight 80
anything I can check?
Thanks
