System Version NethServer release 7.4.1708 (Final)
Kernel 3.10.0-693.11.1.el7.x86_64
Hello Folks, i try to figure out if there is a possibility to monitor the Network Traffic inside a Lan with the Nethserver. Any Tips for that?
Thanks in advice
Thanks in advice
Please have a look at the following link
http://www.binarytides.com/linux-commands-monitor-network/
I installed iptraf, but no more testing till know.
If you want to install it:
yum install iptraf
you have to call it with
iptraf-ng
You can also install ntopng:
yum install nethserver-ntopng
And if you feel brave and want to test the latest release (we already use it in production):
yum --enablerepo=nethserver-testing install nethserver-ntopng
Good Morning and thanks a lot for your Help. I have installed he nethserver-ntopng from nethserver testing and from what i see it should be working. the service is up and reachable from green on port 3000. But if i go there i receive the message
Nethgui:
404 - Language not found
1377519247
what can i do?
Okay, seems to be working right now, but got Probs to enter Lightsquid and Statistik Page now…
Some errors at the logs?
nothing to see, its just not rechable… no idea at the moment.
Probably httpd-admin didn’t reloaded correctly.
Try to execute:
systemctl restart httpd-admin
i guess something in that way went wrong. If i try to go from the netgui and reach Lightsquid i got an “can not connect to the server under localhost.” when i try to reach ntop i got an Service Unavailable
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
but if i go from the netgui bandwidth ntop works and also from the bandwith monitor it works perfekt.
