Matrix - synapse
(yes, I saw the smiley) I really didn’t see any reason to–the Ansible deployment is thoroughly documented on its own GitHub page, and with a few tweaks (noted up-topic) it’s worked well for me on a free Oracle Cloud instance. Adding Signal, Telegram, Whatsapp, and other features was plug-and-play. But docs on getting the iMessage bridge working (and working in such a way as to not mess with the Ansible installation) were very sparse and fragmentary, so I figured that was worth writing up.
But I will say that the script I linked to (to install macOS under Proxmox) works surprisingly well. It’s slow, though–it took hours to complete the installation. But even so, it worked perfectly to install macOS Monterey in a VM on my Proxmox cluster, complete with a unique serial number that allowed me to log in to iCloud/iMessage (which was the whole point of the exercise).
With the help of @mrmarkuz I managed to install WA bridge on my matrix-synapse instance using the docker route (portainer)
I am confronted with 1 (minor) issue:
when adding an avatar for my account on matrix-synapse server using element client application, WhatsApp users don’t see that avatar.
Is there a setting to propagate such info from matrix to WA ecosystem? Or do I have to edit this on the WA client that is connected to the WA bridge?
I’d rather have the option to set avatar and status in Element…
any ideas?
It seems you need to set the avatar in the Whatsapp client to sync it to the bridge. I wasn’t able to push the avatar from element to WA in my tests…
So, a bit of an update… I had some trouble with my macOS VM, and updates to the bridge now require macOS Ventura anyway, so I started over. The scripted installation of macOS that I’d previously used didn’t seem to work properly with Ventura, so I installed it manually instead. It’s otherwise continuing to work well. I’ve made a few updates to the wiki entry, and moved it to a wiki.js installation:
I’m expecting to make a few other updates there, but this is repeatable for me.
