I restarted the containers many times, but synapse stops and restarts by cycles of a few seconds. While starting, it is 172.28.0.2. db is 172.28.0.4
Following command shows all logs of all containers:
docker-compose logs
Log is very long, how can I send it?
You may use a service like pastebin.
I got the logs from portainer, loops are removed.
You can get them here.
From the logs it seems the db container isnât reachable from synapse and whatsapp container.
Are you sure that the containers are using the aqua network?
Maybe the configuration steps changed since I wrote the howto. Iâm going to test it again when I find time.
