Also we had a big problem with samba upstream update last year.
But if we can find a solution, it is a very good thing.
Iām completely with you and your comment is really welcome. You didnāt interrupt, you enriched this discussion.
What frustated me is, that itās impossible to setup a stable machine. And thatās a difference to others.
You have the choice between an old maybe buggy and instable machine and a instable alpha-release machine. Nothing between. And thatās IMO the bad thing.
That updates can break something and that an admin has to decied what to install and that she/he is reposible for her/his work Iām absolutely aware.
@davidep sorry to bother you again, but I need your opinion.
I created a repo-file called āCentOS-temporaryā with this content:
# CentOS temporary contains rpms from CentOS 7.4.1708
[C7.4.1708-extras]
name=CentOS-7.4.1708 - Extras
baseurl=http://mirror.centos.org/centos-7/7.4.1708/extras/x86_64
gpgcheck=1
gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-CentOS-7
enabled=1
[C7.4.1708-base]
name=CentOS-7.4.1708 - CentOSPlus
baseurl=http://mirror.centos.org/centos-7/7.4.1708/os/x86_64/
gpgcheck=1
enabled=1
[C7.4.1708-updates]
name=CentOS-7.4.1708 - Base
baseurl=http://mirror.centos.org/centos-7/7.4.1708/updates/x86_64/
gpgcheck=1
enabled=1
[C7.4.1708-centosplus]
baseurl=http://mirror.centos.org/centos-7/7.4.1708/centosplus/x86_64/
gpgcheck=1
enabled=1
With the standard-centos repos disabled and this enabled, I can install the latest 7.4 stable version with kernel 3.10.0.693.21.
Is this compatibel with nethserver-repos-content?
Or in other words: Bad or good idea?
EDIT: This is no longer available. Repo moved to Centos-vault!
I donāt think that Iām qualified enough for a definitive answer, but it seems a good idea. (AFAIK, Davide is offline)
If we assume that the install ISO for NethServer is stable. What if NethServer implemented the LVM snapshot method before installing updates. If the update process went wrong the user could roll back to previous good snaphot?
I donāt actually know how that would be implemented, but it sounds like a solution to recovering a Linux Server from a bad update.
bob
Yes Iām on holiday now
If you can, wait the beta release next week. Your idea seems good but I cannot ensure it works. Read carefully the ārelease lockā thread for more info
And that says a lot how much devs care about the community
