NethServer Version: 7 on centOs 7 Module: your_module (What does it mean ?)
Hello I discovered recently centOs7 and netServer7, but I can’t log into nethserver at https://IP:980, using the login root and password Nethesis,1234:
“Password: Invalid credentials”
Hi @Thierry,
First of all: welcome to the NethServer comunity! I am glad you found us.
Can you tell a bit more how you installed NethServer? Did you use a dedicated pc/server or did you install in a virtual environment?
Secondly: did you install using the unattended option or did you use the Advanced option?
You are able to get to the login page for your NethServer?
On what IP address is your server installed and how does that relate to the rest of your network?
