Saved to a file:
Hope this works! ![]()
Saved to a file:
Latest core release 3.12.2 has a bug. I think you should have it. In this case you can downgrade to 3.12.1 with a command like:
api-cli run update-core --data '{"core_url":"ghcr.io/nethserver/core:3.12.1", "nodes":[1],"force":true}'
Replace the node Id with your value(s).
Then restart Mail as explained before.
Bug reference: Requested/Renewed TLS certificate not applied · Issue #7679 · NethServer/dev · GitHub
Released Release 3.12.3 · NethServer/ns8-core · GitHub
After Core Update, if the application still presents the old certificate, restart it from Software Center.
That has fixed it. I knew the errors started after I updated, just Mail or Core I didnât know. I wonât update core for the next couple weeks.
Thanks David!
Itâs a core 3.12.2 bug. I added a get_certificate function to the Python agent library, but that name was already used. My mistake /cc @stephdl
A fix for this will be released as core 3.12.3.
Edit: Released Release 3.12.3 · NethServer/ns8-core · GitHub
trueâŠ..one task, one fully qualified domain name
Weâre only human â we make mistakes. But what truly matters is how we handle them.
In the middle of the big Nethesis event, @davidep and @mrmarkuz stepped up and fixed the bug.
no wonder i was facing issues. THanks for the fix
